Thread: alternator voltage bypass?
Results 1 to 5 of 5
  1. #1 alternator voltage bypass?
    Michigan
    when I first start my car the voltage is usually between 14.4-14.6 volts but when I start driving it quickly drops to 12.7-12.8 and sits there. I've been told that this is a gas saving mechanism but seeing as I will be running roughly 3000 rms worth of system I need my voltage to float between 14.3-14.6 while I'm driving. is there a way to bypass this?
  2. #2 Re: alternator voltage bypass?
    What do you drive?
    Voltage goes up to charge the battery. When the 12 volt system is running all you really need is 12 volts. We have grown accustomed to a little more, but 12 is expected.
    To upgrade it..you want to do the voltage mod or get a voltage booster.
  3. #3 Re: alternator voltage bypass?
    Michigan
    zzp doesn't offer a voltage booster for 05+ and when I'm running over 3000 watts worth of system a high voltage is necessary
  4. #4 Re: alternator voltage bypass?
    So i'm guessing you have an 05+ car because you didn't tell us what year and model you are driving.
  5. #5 Re: alternator voltage bypass?
    Michigan
    sorry it's a supercharged 07 gt
  1. Voltage drop from alternator
    By NyteSniper in forum General Tech Discussion
    Last Post: 06-12-2011, 06:26 AM
  2. High voltage bypass?
    By Big Dave in forum General Tech Discussion
    Last Post: 04-20-2010, 07:06 PM
  3. Alternator voltage boost
    By abuckley1290 in forum General Tech Discussion
    Last Post: 04-04-2009, 02:21 PM
  4. Idle voltage....Alternator?
    By Damojo2003 in forum General Tech Discussion
    Last Post: 12-05-2008, 06:52 AM
  5. Alternator Voltage booster gone wrong
    Last Post: 03-19-2008, 03:44 PM
