Thread: An all out A/C / Heater Problem
Results 1 to 6 of 6
  1. #1 An all out A/C / Heater Problem
    Sep 2011
    Arizona
    New to this forum and tried searching for a fix on this problem. I don't wanna take this to a mech because it seems like it would be an expensive fix, so I'm going to try and tap resources on this site first. Oh and BTW this problem shows up a lot when I searched for it, if you have something similar or have in the past share what you can.
    I have a 2002 GP SE with a 3.1 with bout 150000 miles on it (it has a manual dual heat control on it). The AC / Heater unit has given me a headache... First off it started with it not responding to my setting unless I moved my temp gauge up and down repeatedly before it would respond. After it went out completely on my passenger side. I get outside temp air blowing in on my passenger side. Soon after that I lost control of my vent settings. No matter what the setting I put it on it seems to blow out all vents and the A/C seems to be engaged no matter what (i think this because I can hear the car idle a tiny bit more when I engage the heater / ac) Last my driver side recently will only blow out hot air no matter what. I have had the heater core and cooling system flushed but other than that haven't done much else to try and correct this problem. I read on here that this is a COMMON problem and couldn't find an answer. If you have any input that would be tight.
  2. #2 Re: An all out A/C / Heater Problem
    SE Level Member jmt455's Avatar
    SE Michigan
    Here are a couple of the most common causes & solutions:
    http://www.grandprixforums.net/quest...ing-22860.html
    From yourr description, I'd guess it's the actuator(s), but a vacuum leak will wreak havoc on these controls so I'd check that first.
    83 Bonneville wagon
    08 G8 Base
  3. #3 Re: An all out A/C / Heater Problem
    Sep 2011
    Arizona
    Awesome that gives me a start of sorts, thank you much. I couldn't find anything like this.
  4. #4 Re: An all out A/C / Heater Problem
    Sep 2011
    Arizona
    Okay so I have one problem solved, the actual blend door motor that isn't allowing a temp change, but the problem now leads to the actual venting controls. from what I've been reading this has to do with a vacuum actuators... I think... Does anyone have a diagram or something detailed about getting to these lines so that I may check em?
  5. #5 Re: An all out A/C / Heater Problem
    SE Michigan
    PM sent re: FSM schematics.
    83 Bonneville wagon
    08 G8 Base
  6. #6 Re: An all out A/C / Heater Problem
    SE Level Member Skrappi69's Avatar
    USA
    JMT455 - Ciould you send me a copy of those scematics as well? I have the same issue as HDGlassArt
    Thanks.
  1. problem reaching heater core?
    By iroc2 in forum Off Topic Discussion
    Last Post: 02-14-2011, 10:32 PM
  2. 2003 Gr Prix Heater Problem and other issues.
    By kennn in forum General Tech Discussion
    Last Post: 10-27-2010, 08:45 PM
  3. ac/heater blower problem
    By edman thomp in forum General Tech Discussion
    Last Post: 08-26-2010, 08:03 PM
  4. Heater/defog problem
    By GazV6GT in forum General Tech Discussion
    Last Post: 01-23-2009, 09:11 AM
  5. Heater Blower Problem
    By duncanmi in forum General Tech Discussion
    Last Post: 11-24-2008, 09:46 AM
