Thread: Throttle body bolts!
Results 1 to 20 of 21
  1. #1 Throttle body bolts!
    GT Level Member gunsn88's Avatar
    May 2011
    Vineland, New Jersey, United States
    im trying to change my throttle body bolts that conect it to the manaford but i dont know what torx size it is can someone help me?
    Imagination is more important then knowledge.
  2. #2 Re: Throttle body bolts!
    What year/model do you drive.
    97-03 is a 10mm nut on a stud.
  3. #3 Re: Throttle body bolts!
    May 2011
    i have a 01 gt. i took the nut off but the two sides of the bolt have reverse torx on them.
  4. #4 Re: Throttle body bolts!
    There are three studs with E torx put into the supercharger. Then the TB sits on those and it is then fastened to the SC via three 10mm nuts. Kinda sounds like you missed one.
  5. #5 Re: Throttle body bolts!
    May 2011
    oh no theres no super charger on it its just the normal throttle body conected to the manafold
  6. #6 Re: Throttle body bolts!
    Ok then..
    Three nuts.. all 10mm. Same on all 97-03 3800's whether you tell us what you drive or not.
  7. #7 Re: Throttle body bolts!
    May 2011
    i got all three nuts off. but the bolts seem like theyre in a sleev in themanafold side. both sides have reverse torx on them and someone on here told me to use a normal mm or inch socket but that almost striped it. theyre in there pretty good.
  8. #8 Re: Throttle body bolts!
    Take a picture
  9. #9 Re: Throttle body bolts!
    May 2011
    ok how do i post it on here
  10. #10 Re: Throttle body bolts!
    Use photobucket or a similar hosting site
  11. #11 Re: Throttle body bolts!
    Wait up.
    You got an NA. Take a look on the side of the throttle body at the black bracket (not the one for the cables, the other side).
    Move that bracket and you'll have the TB off.
  12. #12 Re: Throttle body bolts!
    HUDSON
    Just lock two nuts together back to back on each of the studs and remove with a wrench.
  13. #13 Re: Throttle body bolts!
    May 2011
  14. #14 Re: Throttle body bolts!
    May 2011
    how would that work?
  15. #15 Re: Throttle body bolts!
    Dude..look at the front side (facing radiator) of the TB. Got a black bracket and bolt there?
  16. #16 Re: Throttle body bolts!
    Your pic still shows the nut on it.
  17. #17 Re: Throttle body bolts!
    May 2011
    i mnt when the nut and throttle body are off the studs are still there. im just having a hard time with um. also i got new head lights but theyre giving me isues. teyre aftermarkets. the ones forging up and the other has a part that fell off that holds the top adjustment thread. im about to send them back.
  18. #18 Re: Throttle body bolts!
    Holding the throttle body on. Remove the nuts holding it to the manifold. Remove the bolt/stud holding a bracket to the front of it (kinda by the radiator hose at the engine) and it should come right off. If not..you are missing taking something off.
    Since my magical powers aren't up to snuff yet.. I don't know where the EFF "vineland" is and can't recommend a buddy or any locals to give you a hand.
  19. #19 Re: Throttle body bolts!
    May 2011
    vineland in the middle of bumblef^&ck lol a unknown and cared for town
  20. #20 Re: Throttle body bolts!
    Odd, I've never heard of that state
  1. LS1 Throttle body
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2012, 05:16 PM
  2. throttle body bolts
    By chunky in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 04:22 PM
