Thread: Abs tcs light
Results 1 to 2 of 2
  1. #1 Abs tcs light
    Oct 2011
    mn
    anyone know what is tripping these codes c0236 c0896 c0550
    My abs and tcs light come on when driving, then my steering gets harder
    I can park the car go out next morning or later in day light will be off after driving for a little bit comes back on.
    Was wondering anyone has had same simler problem.
    One thing I did was this plug I put one in from Pontiac grand prix 3100 engine there different My volt went crazy talking 15.7V or more little box shows car doors went blank then came back on. I only got abs tcs light after install of alt plug from 3100 engine. I have right one now.
    http://i245.photobucket.com/albums/g...n/IMAG0100.jpg
    I did a search found this write up on Stuff in bold
    Could Of I damaged the ebcm? I would I know If I did?
    DTC C0896: DEVICE VOLTAGE RANGE/PERFORMANCE
    Circuit Description
    EBCM is required to operate within a specified range of
    voltage to function properly. During ABS and TCS operation, there are
    current requirements that will cause voltage to drop. Because of this,
    voltage is monitored out of ABS/TCS control to indicate a good
    charging system condition, and also during ABS/TCS control when
    voltage may drop significantly. PCM also monitors for high voltage
    conditions which could damage EBCM.
    DTC sets when EBCM operating voltage at terminal No. 8 (Pink
    wire) drops to less than 9.4 volts out of ABS/TCS control, or 8.8
    volts during ABS/TCS control, or EBCM operating voltage at terminal
    No. 8 increases to greater than 17.4 volts. Condition must exist for
    more than 500 milliseconds with vehicle speed above 3.6 MPH.
    Diagnosis
    Electronic Brake Control Module problems please help! - LS1TECH
  2. #2 Re: Abs tcs light
    Pennsylvania
    Quote Originally Posted by stcspiderman View Post
    Sounds like your EBCM fried... ours are apparently notorious for taking more juice than they can handle - rebuilders solder in parts to keep this from happening. Do a search and you'll find plenty of info here from the past couple months.
    As for your wiring... if your battery voltage is surging, you've got another problem entirely aside from your EBCM.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  3. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  4. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
