Thread: plastic elbow 3800
Results 1 to 8 of 8
  1. #1 plastic elbow 3800
    Oct 2011
    juliette ga
    need to replace plastic elbow going to heater core. any advice on doing this? 2005 grand prix 3800 engine
  2. #2 Re: plastic elbow 3800
    SE Level Member kyrebel's Avatar
    Dec 2010
    Louisville, Kentucky, United States
    are you talking about the ones that run through the tensioner mount body?
  3. #3 Re: plastic elbow 3800
    Brewcity, WI
    http://www.grandprixforums.net/plast...ent-44320.html
    I'm not aware of more then 2 plastic elbows?
    Self-denied SMGPFC member #1
    SEARCH works!
  4. #4 Re: plastic elbow 3800
    SE Level Member KirkpatrickJTK's Avatar
    Oct 2011
    Urbandale, Ia
    If your referring to the elbows the run threw the tensioner they are a pain as they are tight fit and the alternator may or may not get in the way I just removed my alternator when mine cracked
  5. #5 Re: plastic elbow 3800
    Brewcity, WI
    Quote Originally Posted by KirkpatrickJTK View Post
    um they aren't that hard.... but if you didn't remove the alt. I could see why you say that
    SEARCH works!
  6. #6 Re: plastic elbow 3800
    Oct 2011
    Urbandale, Ia
    Yeah if your lazy and do not take of the alt your probably SOL. I only claim it as a pain because I has to replace the whole tensioner at that time tight fit when you have large hands. My tensioner pulley bolt snapped. Not sure how it managed that. But it was no fun.
  7. #7 Re: plastic elbow 3800
    Dec 2010
    i just replaced these about 2 weeks ago had the lim out changing gaskets out so it took a little bit of yellin and cussin but came out with no problem. i do see how trying to do this with out either bring in the middle of removing lim or removing the alt could turn into a pretty big headache
  8. #8 Re: plastic elbow 3800
    That's because it's reverse thread. Loosen the opposite way that you relive pressure on the belt.
    On the cussing and screaming about the the elbows. I hear some Jeff Dunham phrase...lol Seriously though. It's loosen a belt, pull the alt and a few other bolts. Wiggle, lube and tighten.
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
  3. plastic elbow replacement
    By jspangler22 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2011, 08:47 PM
  4. Plastic elbow
    By Coolride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2011, 06:47 PM
