Thread: Aftermarket Oil Pressure Sender
Results 1 to 2 of 2
  1. #1 Aftermarket Oil Pressure Sender
    GT Level Member ls1camino's Avatar
    Laurel, MD
    So, I installed an Autometer Oil Pressure Sender and gauge in my 2000 GTP. I put the sensor in the oil filter adapter where the stock sender is. Everything went in fine, I ran the one wire from the sender to the back of the gauge. I start the car and the needle barely moved from the "powered off" placement, but never even reached the 0 on the gauge.
    I first thought it was the tephlon tape blocking the ground from the motor to the sender, then I didn't use the tape and nothing changed.
    Did I install something wrong?
    I highly doubt something is wrong with the sender or gauge since they were never opened, though I've had them sitting in a box from a previous project for over 5 years.
    Here is the gauge:
    Auto Meter 4927 - Auto Meter Ultra-Lite II Analog Gauges - Overview - SummitRacing.com
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: Aftermarket Oil Pressure Sender
    St. Louis
    Check the nuts on the back of the gauge itself and be sure they're tight even if you aren't using them for anything. When I installed my Pro-Comp gauges my oil pressure read fine for a minute then as I was driving it dropped to 0. I about had a heart attack until I pulled the gauge from the pillar pod and noticed the nuts were loose. Tightened them up and the gauge works fine.
  1. fuel sender issue
    By dlz47 in forum General Tech Discussion
    Last Post: 08-11-2011, 12:12 PM
  2. Fuel sender - need to replace?
    By Skrappi69 in forum General Tech Discussion
    Last Post: 04-06-2011, 02:44 PM
  3. how to install a oil pressure sender
    By Will5600 in forum General Tech Discussion
    Last Post: 04-08-2010, 07:01 AM
  4. Hooked up a Fuel Pressure Sender (with pics)
    By BlackGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2008, 09:28 PM
  5. Tranny Sender Type?
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2008, 08:32 AM
