Thread: Is my HUD dim?
Results 1 to 13 of 13
badata Is my HUD dim? 06-20-2008, 08:31 PM
Preotic Re: Is my HUD dim? 06-20-2008, 11:34 PM
GTP00Matt Re: Is my HUD dim? 06-21-2008, 07:48 AM
archemedes Re: Is my HUD dim? 06-21-2008, 09:49 AM
Warhellride Re: Is my HUD dim? 06-21-2008, 12:19 PM
badata Re: Is my HUD dim? 06-21-2008, 08:15 PM
Risinnfallen Re: Is my HUD dim? 06-21-2008, 09:45 PM
crimpton Re: Is my HUD dim? 08-18-2008, 10:47 PM
Warhellride Re: Is my HUD dim? 06-22-2008, 10:02 AM
badata Re: Is my HUD dim? 06-23-2008, 05:47 PM
Sabrewings Re: Is my HUD dim? 06-23-2008, 09:05 PM
bentendo92 Re: Is my HUD dim? 08-03-2008, 04:19 PM
offroadfury6 Re: Is my HUD dim? 08-07-2008, 07:09 AM
  1. #1 Is my HUD dim?
    Feb 2008
    I drove a 06 grand prix the other day and noticed that the hud was alot brighter than my 01. I know its a different HUD unit because it has temp and direction and on it . Is it possible for HUD to start dimming? I heard the windshield may be a factor if it was ever replaced with a non hud glass. Does anyone know how to tell or any ideas?
    2001 GTP- ZZP Catless DP, 180 t-stat, Wizaired CAI
    98 LS1 TA 361RWHP 360RWTQ, Cam, Intake & Exhaust
  2. #2 Re: Is my HUD dim?
    GT Level Member Preotic's Avatar
    Missoula, MT
    Your car may have a non HUD window in it. The HUD wouldn't be as bright.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  3. #3 Re: Is my HUD dim?
    SE Level Member GTP00Matt's Avatar
    May 2008
    Delavan, MN
    04+ HUD is quite a bit brighter then the older ones, just the way it is, unless yours is really dim it's probably the way it's supposed to be.
    2000 GTP coupe, totally stock
    1995 Chevy K2500 6.5 TD 4" straight pipe 285 BFG's on 16x8 American Racing Nitro's
  4. #4 Re: Is my HUD dim?
    Saraland Alabama
    they also do dim with age
  5. #5 Re: Is my HUD dim?
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    One way to tell if your HUD is dimming is to go over 100 MPH (not recommended on public roads) or go over 60 MPH and switch to metric (recommended on the highway). Since the 1 in your HUD speedometer doesn't get used too much, it'll be a lot brighter if the other numbers are getting dimmer, which does happen with age.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  6. #6 Re: Is my HUD dim?
    Feb 2008
    Cool, I will hit triple digits tommorow see how the 1 looks. Anyone have a idea of how to check if the glass is stock? Or has HUD? i didnt buy the car new so it may have been changed. On the lower passenger side it says made in canada, and some numbers i will recheck.
  7. #7 Re: Is my HUD dim?
    SE Level Member Risinnfallen's Avatar
    Lombard, IL
    i notice sometimes mine dimms then i give er a smack and she lights back up...
  8. #8 Re: Is my HUD dim?
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    Quote Originally Posted by Risinnfallen View Post
    This is due to a cold solder connection on the light sensor. There are several write ups about this on most boards. I've resoldered a couple HUD's to make them bright again.
    Age is also a problem but if you can make it brighter, or it comes and goes on it's own you can try the solder trick.
  9. #9 Re: Is my HUD dim?
    ^^There are two things that usually make these HUD's dim: age (can't do anything about that), and something screwed up in the electronics. Mine's never dimmed on me with it set to maximum brightness, but if I try to dim it manually (when I first got it it was too bright at night), it will sometimes dim then work its way back up to full brightness.
    Since the OP's in a 2001, I'd guess it's probably just dimmed with age.
  10. #10 Re: Is my HUD dim?
    Feb 2008
    As soon as i hit triple digits I saw the brightest #1 i ever saw on the windshield! I guess its true they dim with age.
  11. #11 Re: Is my HUD dim?
    Barksdale AFB, LA
    The HUD is more than likely run by a VFD. They are known to go dim over time... Just the nature of their design.
    2009 Subaru Impreza WRX STI
  12. #12 Re: Is my HUD dim?
    SE Level Member bentendo92's Avatar
    Aug 2008
    New Hampshire
    I thought mine was dim one day...
    Then I took off my sunglasses....
  13. #13 Re: Is my HUD dim?
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    well my 06 GP has an auto dim, it will be bright in daytime and at nite it will like vise versa and lower the site when it thinks its getting dark...
dim, hud
