Thread: 2000 Grand Prix GT HELP
Results 1 to 19 of 19
  1. #1 2000 Grand Prix GT HELP
    Oct 2011
    Stow,OH
    Okay I have a 2000 Grand prix gt 3800 series II. Runs great but when you drive and press the pedal too far down it wont go. you cannot gun it. You have to baby it up to speed which really makes people behind me pissed. Ran 3 codes. PO131 PO134 and then multiple missfire. The Codes are with o2 sensors. 1 was already replaced. Please help me out guys it would be greatly appreciated. Thanks guys
  2. #2 Re: 2000 Grand Prix GT HELP
    does the SES flash at all?
    And I kinda wanna take a guess at saying maybe your cat is clogged with how bogged down it get beyond 1/2 throttle.
  3. #3 Re: 2000 Grand Prix GT HELP
    Oct 2011
    Stow,OH
    I dont think it does what does the ses stand for? (new pontiac owner) and you would think o2 sensors with the o2 sensor codes
  4. #4 Re: 2000 Grand Prix GT HELP
    service engine soon, check engine light
    Well what do the o2 sensors do?
    They monitor your emssions and air and fueling. So in turn they monitor the effectivness of your cat converter.
    Go grab a pressure gauge and take the upper o2 sensor out and screw the pressure gauge in its place and start the car, if the pressure gauge read more than 1-2 psi your cat is clogged.
  5. #5 Re: 2000 Grand Prix GT HELP
    Jun 2011
    You may have too much back pressure, making the engine work harder.
    Dont drive it if the ses light is flashing... its damaging your 02 and cat.
  6. #6 Re: 2000 Grand Prix GT HELP
    Oct 2011
    Stow,OH
    Yes the service engine soon light is on..but then itll turn off sometimes and wont turn back on for quite a while maybe a day or two....Im gonna check the sensor behind the cat later and then i might just go buy a new cat also
  7. #7 Re: 2000 Grand Prix GT HELP
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    just check to see if its flowing before you buy a new cat
  8. #8 Re: 2000 Grand Prix GT HELP
    Oct 2011
    Stow,OH
    Im going to try and replace the o2 sensor tomorrow and hope to god that it fixes it..Worse case senario i go get a cat from summit racing for $50
  9. #9 Re: 2000 Grand Prix GT HELP
    Charles City, IA
    pull the front 02 out and take it for a drive and see if its better.
    SMGPFC Two Nipple General
  10. #10 Re: 2000 Grand Prix GT HELP
    Quote Originally Posted by TheOtherNick View Post
    As in remove
  11. #11 Re: 2000 Grand Prix GT HELP
    Oct 2011
    Stow,OH
    ohhhh lol okay...and it should run better? and if it does then what?
  12. #12 Re: 2000 Grand Prix GT HELP
    Oct 2011
    Stow,OH
    I took it out and no difference still doing the same thing...
  13. #13 Re: 2000 Grand Prix GT HELP
    Jul 2011
    Michigan
    ^^^this will probably be the easiest/fastest test
  14. #14 Re: 2000 Grand Prix GT HELP
    sigh
    or what I said, but listening is just too hard nowadays.
  15. #15 Re: 2000 Grand Prix GT HELP
    Jul 2011
    Michigan
    and what exactly happens when you "gun it". does it bog down or does the motor stumble (like a real bad misfire). do plugs and wire.
  16. #16 Re: 2000 Grand Prix GT HELP
    Oct 2011
    Stow,OH
    replaced o2 sensor behind the cat and it did not fix it...top one was replaced already...im going for clogged cat...when i gun it it bogs down a little and acts like a bad misfire yes
  17. #17 Re: 2000 Grand Prix GT HELP
    Oct 2011
    Stow,OH
    i unplugged the top sensor and it didnt change the car at all
  18. #18 Re: 2000 Grand Prix GT HELP
    Jul 2011
    Michigan
    here is what needs to be checked
    -fuel delivery
    -air delivery
    -flow (as in exhaust)
    -sufficiant spark to ignite the fuel
    now when you figure that out^^^good luck finding what is causing that problem
    ex. there are many sensors that can effect air/fuel problems.
  19. #19 Re: 2000 Grand Prix GT HELP
    Oct 2011
    Stow,OH
    fuel is getting enough pressure...im takin the cat off tomorrow and gonna see what happens
  1. 2000 Grand Prix
    By 2005GrandPrix in forum Members Rides
    Last Post: 02-01-2011, 08:36 PM
  2. i need help with my 2000 grand prix gt
    By aaroncarroll in forum Off Topic Discussion
    Last Post: 07-12-2010, 02:45 PM
  3. 2000 grand prix gt
    By candt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2008, 10:41 AM
