Thread: Coil Bracket difference? (Pics added)
Results 1 to 9 of 9
  1. #1 Coil Bracket difference? (Pics added)
    SE Level Member DRWBRTq19's Avatar
    Jefferson City MO
    Can someone tell me what the difference is between the L67 coil brackets and the L36 coil brackets?
    Pics to further illustrate this difference would also be very welcome.
    Thanks
    Drew
  2. #2 Re: Coil Bracket difference?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Hard to explain but I'll try:
    L67 - Coil packs bolt directly to the ICM and the ICM bolts to the ICM bracket.
    L36 - Coil pack bolts go through the coils, and ICM and screw directly into the ICM bracket.
    They are not interchangeable.
  3. #3 Re: Coil Bracket difference?
    Hoffman/Schaumburg, IL
    Also the pass side torque strap(dog bone) is directly part of the l67 coil pack while the L36 is a separate unit.....Also 2 pulleys mount to the bracket for the s/c's belt system, and the L36 bracket doesn't have provisions for those
  4. #4 Re: Coil Bracket difference?
    Las Cruces, NM
    True, I was just speaking to the actual ICM itself but yes, that is all correct about the mounts too.
  5. #5 Re: Coil Bracket difference?
    Barksdale AFB, LA
    I believe the exact location of the coils is a bit lower with the L36 bracket too. That leads me to believe that the L67's is lifted to clear the SC belt. With my PRJ wires (made for L67) the #5 cylinder wire is a little bit more taught than I see on pics of L67s. This may also be a factor of the different design of the L36 passenger side mount and the L67 passenger side mount.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Coil Bracket difference?
    Jefferson City MO
    Ok, so this is all good info... But I'm a very visual person, can someone tell me which one of the two this one is?
    Drew
  7. #7 Re: Coil Bracket difference? (Pics added)
    Jefferson City MO
    bump for pics
    Drew
  8. #8 Re: Coil Bracket difference? (Pics added)
    Oklahoma
    That looks like an L67 bracket. Id have to go grab mine and compare to be certain, but it looks like the L67.
  9. #9 Re: Coil Bracket difference? (Pics added)
    Jefferson City MO
    Now thats what I was thinking... but thats weird cause its the exact same one on my GT.
    Drew
  1. difference between 04-05 gtp and 06-07 gt?
    By miller in forum Off Topic Discussion
    Last Post: 04-12-2014, 06:36 PM
  2. Is there a difference between 05 and 06 GXP
    By baw1099 in forum Off Topic Discussion
    Last Post: 06-29-2008, 10:17 PM
  3. lighter coil pack bracket?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2008, 08:29 PM
