Thread: Heater fan in 97 GTP issue.
Results 1 to 2 of 2
  1. #1 Heater fan in 97 GTP issue.
    Oct 2011
    Roseville, OH
    My heater fan refuses to come on no matter how much I mess with the controls, the auto light stays off and the man on the screen blinks. I get heat but it does not blow in, although once in a while it will automatically kick on when I don't want it on and I can shut it off and turn it back on a few times then it refuses and the problem happens all over again. Any ideas?
  2. #2 Re: Heater fan in 97 GTP issue.
    GT Level Member sic6's Avatar
    san marcos, tx
    Check the interior temp sensor behind the vent. It's on the right lower side next to the steering column. You will see 3 slots, your sensor is behind it. If it is dirty or has a loose connector it will cause issues with the climate control.
    97 GTP
  1. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  2. Heater messed up (switches KPH so MPH) DIC won't turn on of heater.
    By Colossus in forum General Tech Discussion
    Last Post: 03-06-2011, 01:13 AM
  3. Heater help
    By dgjks6 in forum General Tech Discussion
    Last Post: 12-27-2010, 04:53 PM
  4. a/c and heater
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2010, 03:22 PM
  5. Need heater help.
    By the955iman in forum General Tech Discussion
    Last Post: 10-26-2009, 04:07 PM
