Thread: A/C not blowing cold
Results 1 to 7 of 7
  1. #1 A/C not blowing cold
    Jun 2012
    Edgerton MO
    I have a 99 grand Prix GT that I'm having problems with the a/c. I charged the ac and my blower is running but no cold air. I can get air out of the floor, the vent, and the defrost but I can't get cold air. My ac circuit is running fine but Im wondering if it is a mised air damper issue. I have dual climate control and I know both sides of the car have dampers but Im wondering if there is another one by the heater core and evaporator? any help would be greatly appreciated.
  2. #2 Re: A/C not blowing cold
    are you getting hot air? or warm outside air?
    is the clutch on the compressor turning when the a/c is on, as well as both fans turning on when the a/c is on?
    im thinking blend door actuators or low freon. if the clutch is not engaging.
  3. #3 Re: A/C not blowing cold
    Jun 2012
    Edgerton MO
    Yes the clutch is engaging. I checked the pressures and the compressor is running fine. Im just getting warm air. I believe my fresh air damper is working bc I hear the pitch of the blower change when I turn it to recirculate.
  4. #4 Re: A/C not blowing cold
    next step is the blend door actuator.
    if you take this little bastard off and turn that small knob it sits over one way or another, you get full heat or full a/c. ( on that side only) driver side is fun to get to. you need to take off the plastic under the wheel, by your knees, then the steel knee bolster, 4 bolts i think, and the foot cover by your feet. if you look threw the front with a light you can kinda see this thing. it has 2 very small bolts that hold it in and they are kinda hard to get to, i used a nut driver to get the bolts out. the only real reason to take all that stuff off the front side, is so you can see what you are doing, you reach up from underneath to get to it.
    truth be told, mine are unplugged for a year now, i take it off and turn the knob where i need it, hot or cold, and then slide the actuator back on, no bolts, it stays put for me. im to cheap to buy another one. so im all jerry rigged lol
  5. #5 Re: A/C not blowing cold
    Jun 2012
    Edgerton MO
    thanks for the info. Im all about rigging. so the car only has two door acuators. There isnt a main one by the evaporator and heater core? I just figured what are the odds for both of them to mess up at the same time.
  6. #6 Re: A/C not blowing cold
    nope that thing controls the hot or cold air only, nothing else as a thing to do with it. just the actuator.
  7. #7 Re: A/C not blowing cold
    Jun 2012
    Edgerton MO
    Thanks again!
  1. 05 GP Air Conditioner Not blowing cold anymore
    By mpoynter31 in forum General Tech Discussion
    Last Post: 05-19-2012, 06:53 PM
  2. Cold air blowing and overheating
    By dj2011 in forum General Tech Discussion
    Last Post: 03-05-2012, 05:25 AM
  3. Overheat and blowing cold air
    By skibender in forum General Tech Discussion
    Last Post: 12-22-2010, 08:57 PM
  4. Blowing cold air
    By tracker1925 in forum General Tech Discussion
    Last Post: 12-11-2010, 06:41 AM
  5. Heater blowing cold on drivers side
    By sophie in forum Introductions/Noob Questions
    Last Post: 11-03-2010, 08:00 PM
