http://www.grandprixforums.net/engine_mount.php motor mount replacement just for you dude lol
thing to think about is tire balancer's dont spin at 50 or 60 mph,(most dont some do) more like 20 to 30 tops, when a tire has broken belts or flat spots from sitting in one spot, it wont show up till high speed, and then the defects start to show their nasty face. i had 2 messed up tires like this in the past.
if you have a friend with tires and wheels that will fit your car swap tires for a ride to see if it goes away, its a free test if you get no change.
some times rotating front to back wont help if all 4 tires are f'ed, ( but its worth a shot) cheap tires seem to fail, you get what you pay for, not that you have cheap-o's on your car, i don't know what you are running on.
there have been at least 3 threads with a mystery vibration, and it turned out to be bad tires, just a thought.
I knew the tires on the car were almost brand new so I didn't even bother to see what kind they were. They are primewell tires. I did some research and they are cheap tires and found some people had the same issue as me... Damnit.. that's not exactly a cheap fix to buy 4 new tires.
