Thread: What other GM parts are swappable with 08 GP
Results 1 to 4 of 4
Sbcook1911 What other GM parts are... 10-02-2011, 06:52 PM
gunsn88 Re: What other GM parts are... 10-07-2011, 10:18 PM
CTKGP09 Re: What other GM parts are... 10-08-2011, 12:42 AM
boostedcompg Re: What other GM parts are... 10-08-2011, 02:51 AM
  1. #1 What other GM parts are swappable with 08 GP
    Aug 2011
    Va. Beach
    When I was younger, I could tell you what parts and what make n model to snatch junk yard upgrade parts off of. Brakes, suspension, ect.ect. Now I have a 2008 GrandPrix and it's getting time to start doing some "freshening up" got about 90,000 already no problems at all! It was even driven through a flooded road and stalled out in a nor'easter! It was towed home, pluggs pulled, airbox pulled apart and filter replaced! Started fine and still runs great!
    My question to you real Pontiac pros is, what other GM models can I scavenge for better brakes, springs, intakes, and so on. Are there and better GM wheels that fit like GTO? I'm going to need brakes first so are there any bigger/ better rotors callipers, rotor swaps for the rear? Sway bars?
    Any and all advice will be appreciated!
  2. #2 Re: What other GM parts are swappable with 08 GP
    GT Level Member gunsn88's Avatar
    May 2011
    Vineland, New Jersey, United States
    i used 18 inch elbrus rims from a cadilack cts v
    Imagination is more important then knowledge.
  3. #3 Re: What other GM parts are swappable with 08 GP
    Willoughby, Ohio
    the brakes from the Fbodys (camaros, trans ams) and GP GXPs will fit, zzp sells kits and i believe WBS does too. stock springs can be found on the olds intrigues of the same era but not really any "better" ones. as far as intake ur better off just to make ur own, its cheap and you can make it fit exactly how you want. NOW alot of parts are swappable from all the Wbodys like monte carlos, regals, and impalas all depends on which part
  4. #4 Re: What other GM parts are swappable with 08 GP
    utah
    C5 vette brakes work as well
