Thread: how did you go about your topswap
Results 1 to 18 of 18
  1. #1 how did you go about your topswap
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    for those of you who to swapped, how did you go about it.
    motor swap
    kit
    junk yard motor and swapped parts over
    trade car
    and approximate cost if you dont mind. im just trying to find the best way to go about it. mechanics is not a problem here.
  2. #2 Re: how did you go about your topswap
    The Boss Iceman6669's Avatar
    Jun 2011
    Honestly dude just go get a GTP... You will be happier in the end.
    2011 F-150 Yote powered
  3. #3 Re: how did you go about your topswap
    Waukesha, WI
    meh on that advice, gtps have higher insurance if that matters, but theyre factory supercharged.
    top swaps have theyre own problem
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: how did you go about your topswap
    Jul 2011
    Michigan
    Quote Originally Posted by redlinepontiac View Post
    it matters. in the end it will be worth the cost and work of a topswap.
  5. #5 Re: how did you go about your topswap
    easiest thing to do is to do a full motor and trans swap with the PCM and wiring harness to complement it.
    any of the other combinations you NEED to get your car tuned.
  6. #6 Re: how did you go about your topswap
    Omaha, NE
    I figured out what I needed and bought what I needed piece by piece.
  7. #7 Re: how did you go about your topswap
    Quote Originally Posted by jpmiller View Post
    motor swap
    kit
    trade car
    Motor swap isn't a top swap. neither is trading your car.
    Cost depends on what you want to do.
    New balancer or used balancer. They're starting to age and fail.
    Reman heads or used heads. You can get screwed here or be wasting money.
    Gen III vs Gen V blower.
    Stock TB vs N* setup.
    Headers vs Stock manifolds.
    Cheap and slower or pricey and faster.
    You can easily be at or above the cost of a used/new turbo kit by the time you're said and done.
    Quote Originally Posted by Iceman6669 View Post
    Why?
    There are no benefits to it, only downsides.
    Tops swaps have to be done right or not at all.
    To be frank, it very well might be easier to change the heads versus the motor and transmission.
    But then finding a tuner might be difficult.
  8. #8 Re: how did you go about your topswap
    Never Never Land
    I'm gonna have to disagree and say it's easier to swap a motor and trans vs ripping your motor down and putting it all back together.
    And OP...if you're really going for power, a turbo will outperform an M90 all day long.
  9. #9 Re: how did you go about your topswap
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    Most people dont have a cherry picker in their garage. But a fair number have a basic socket set.
    And thats all you need to swap heads.
  10. #10 Re: how did you go about your topswap
    Jul 2011
    Michigan
    why to have to be so specific. top swap, motor swap, or trading all have one thing in common......supercharger. i know what a top swap is. title should have been..."how did you go about supercharging" i guess
  11. #11 Re: how did you go about your topswap
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    I bought a motor that spun a bearing for $200. Took it apart and sent the heads to the machine shop, ended up being cracked. Got another set, still waiting to hear. Ported the SC myself, and all the other parts besides wiring harness are in the garage since I have the other motor. I wouldn't rush into it, just gather the parts slowly
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  12. #12 Re: how did you go about your topswap
    Portland Oregon
    I paid more for insurance on my 02 Impala normally aspirated than I do for my supercharged 04 Comp G
  13. #13 Re: how did you go about your topswap
    Waukesha, WI
    Quote Originally Posted by OH4CompG View Post
    that could be misleading, did you have full equal coverage on both cars? i had collision and liabilty on my 98 GT, that was significantly more then just having liablity on my 99 GTP
    RayRay
    92 Turbo miata
    02 lexus is300
  14. #14 Re: how did you go about your topswap
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Purchased a modded LIM and a Blower, and injectors. Tuned the PCM and put it on.... Still on the stock GT heads.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  15. #15 Re: how did you go about your topswap
    Jul 2011
    Michigan
    Quote Originally Posted by 01gpgt01 View Post
    can i get some more info on this. i thought the heads were a HAVE TO HAVE part for the topswap? and what about the fuel rails, and balancer?
  16. #16 Re: how did you go about your topswap
    its called the SSM90 kit.
    And its grossly overpriced.
    http://zzperformance.com/grand_prix/articles1.php?id=69
    Skip it and get a Z3 kit, 1.9's and a TEP trans.
    Its very disheartening that you focus on that rather than anything else I posted.
  17. #17 Re: how did you go about your topswap
    Jan 2009
    Tallahassee, FL
    ZZP has a kit that modifies the LIM to accept injectors and uses an offset pulley to use only on belt. It is expensive and doesn't give you much room to drop on pullies if that's your plan.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  18. #18 Re: how did you go about your topswap
    Hagerstown,Md
    Quote Originally Posted by Sandman View Post
    3.4 is as low as they go now. I got one of the last 3.25 pulleys they produced. But swapping over to a GTP belt setup isnt out of the question.
  1. Topswap for $500?
    By mattstansbury in forum General Tech Discussion
    Last Post: 09-11-2011, 10:50 AM
  2. GT cam on a L36/L67 topswap?
    By Z34Phoenix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2011, 08:33 AM
  3. L67, L32, or L26 Topswap
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 11:46 PM
  4. 97 topswap?
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2009, 08:53 PM
