Thread: MAF ?
Results 1 to 9 of 9
  1. #1 MAF ?
    Coon Rapids MN
    Can I get a 5.3 V8 maf sensor to work in place of the one for the gtp's ?
    http://i130.photobucket.com/albums/p...07786772-1.jpg
    02 Z71 his: sold gone but not forgotten
    04 GTP his: Bone stock
    03 Z71 hers: 6in lift
  2. #2 Re: MAF ?
    Oklahoma
    Moved to the Tech Lounge
  3. #3 Re: MAF ?
    Coon Rapids MN
    thanks I ment to put it here and put it there
  4. #4 Re: MAF ?
    Barksdale AFB, LA
    I don't see why not if you're outflowing your stocker. But it'd require tuning and maybe some adapter wiring.
    2009 Subaru Impreza WRX STI
  5. #5 Re: MAF ?
    TDCRacing
    Guest
    The MAF out of the newer 6.0L trucks will work with an adapter and tuning. These are also known as an LQ4
  6. #6 Re: MAF ?
    Coon Rapids MN
    I was in to my truck but 5 built trannys in a yr. i just said eff it and got the GTP . now i have the wife truck to play with a lil
  7. #7 Re: MAF ?
    TDCRacing
    Guest
    Just out of curosity why do you want a new MAF? Man 5 in a year is pretty bad.
  8. #8 Re: MAF ?
    Coon Rapids MN
    I was thinking of making a 4in custom CAI. I had the 1-2 shift set way too harsh which kills the 4l60e's. I kept snapin the input shafts
  9. #9 Re: MAF ?
    Bastard Reptile's Avatar
    Kansas City, MO
    The 4.8, 5.3, & 6.0 trucks take the same MAF. Otherwise known as an LQ4 MAF. They work, and you can get them to work with a little table modification with a MAF tune.
maf
