Thread: Air bag light on - Help with possible causes
Results 1 to 15 of 15
  1. #1 Air bag light on - Help with possible causes
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    Since i baught my gp, i have had the ses light on. what is wrong, and how to fix, and what does the light mean?
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
  2. #2 re: Air bag light on - Help with possible causes
    Dan..
    We don't have any magical powers to know why your check engine light is on. Gonna need you to hop to action and take your car to the parts store for a free scan. Write down all the actual codes and numbers. Then post them up after you've googled them all to also supply us with the names of them.
    That'll give us a good starting point on where to suggest you start to fixing the issues.
  3. #3 re: Air bag light on - Help with possible causes
    I know what the check engin light is for. its the ses air bag light. sorry thats my fault, thinking to fast and not being able to type fast. its the air bag light.
    Mods- Intake
  4. #4 re: Air bag light on - Help with possible causes
    I've never seen a Service ENGINE Soon light that related to an airbag issue. Airbag light should be seperate.
    Either way. Read the code, post the code and name. Once we know what the car is complaining about we'll have some idea of how to suggest you fix it.
    Til then
  5. #5 re: Air bag light on - Help with possible causes
    Im sory for the wrong light question, it my srs air bag light. How is that on when my air bags nave never gone off?
    Mods- Intake
  6. #6 re: Air bag light on - Help with possible causes
    When a fault is sensed the light will kick on to warn you of the airbag system potentially having a malfunction.
    Worse case, either they don't deploy in a crash or they deploy when they shouldn't.
  7. #7 re: Air bag light on - Help with possible causes
    St. Louis
    It means there is an issue w/ the airbag system, a malfunctioning component somewhere and the airbag may not work in the event of a crash.
    Worst case scenario the airbag will deploy at random and smack you!
  8. #8 Re: Air bag light on - Help with possible causes
    how and where can i get this fixed at?
    Mods- Intake
  9. #9 Re: Air bag light on - Help with possible causes
    Dealer should be able to fix it. I don't know your local mechanics, so I can't vouch for their equipment or skill level.
    Kinda tough to tell you where/how to fix something w/o knowing what's wrong. Ya know?
  10. #10 Re: Air bag light on - Help with possible causes
    I know. Ill call the dealship and see what they charge, but im assumeing that it will be an arm and a leg. thank for the help.
    Mods- Intake
  11. #11 Re: Air bag light on - Help with possible causes
    I'd expect it to be too.
    But .. say it's just resettting the system, that should be reasonable.
    I rebuilt a car that had airbag deployment. And merely had to reset the airbag deployment code with a Tech2 for the system to be happy again.
  12. #12 Re: Air bag light on - Help with possible causes
    and that took care of the light and nothing else happened?
    Mods- Intake
  13. #13 Re: Air bag light on - Help with possible causes
    Quote Originally Posted by 1996pontiac View Post
    Yeah..I read the code with a Tech2. It was along the lines of bags deployed. There was an option ot reset it and since the new parts were all in the car. The reset worked.
    Use a dealership tool, get dealership results .
  14. #14 Re: Air bag light on - Help with possible causes
    Minnesota
    If its too expensive you could just buy a scanner and look the code up and fix it yourself. That is if you even feel comfortable doing that.
  15. #15 Re: Air bag light on - Help with possible causes
    Minnesota
    Or this:
    Autel
    OR
    Autel
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  3. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  4. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
