Thread: Intermediate No Crank issue and I have researched!!
Results 1 to 4 of 4
  1. #1 Intermediate No Crank issue and I have researched!!
    Fort Wayne, IN
    Ok I found a few threads about this but I just want a second opinion about this. This has been happening for a while and its more of an issue now as it happens about everyday instead of one or twice a month. I did have a worn ignition switch a few months ago but I put a bypass relay in and now my DIC, fan speeds, and defroster now work. But now I'm thinking its a problem....
    About everyday now when I go to start the car... it just clicks. I hear the relay in the dash click but the starter doesn't even try to turn. Now if I keep turning the key to try and start it sometimes it only takes a 2-5 times if I'm lucky but sometimes it takes about 50-100 turns to start and when it does there isn't even hesitation. So..... do you think its the ignition switch? or the trigger wire? Or maybe the solenoid itself?
  2. #2 Re: Intermediate No Crank issue and I have researched!!
    Test the soleniod wire at the starter, if you have no crank and a test light shows power, replace the starter. If you get no power check the trans swtich to ensure it see's part (depends on year) then replace ign switch.
  3. #3 Re: Intermediate No Crank issue and I have researched!!
    Fort Wayne, IN
    So if it is the starter... Would it be just the solenoid or replace the whole starter? I have no clue if its the original starter or not but it does have 170k miles on it.
  4. #4 Re: Intermediate No Crank issue and I have researched!!
    It's tougher to find a soleniod these days.
    Why don't you do the test and let us know what you found.
  1. intermediate steering shaft
    By mstowe in forum Shops and Community Heroes
    Last Post: 10-08-2013, 07:02 PM
  2. squealing noise from crank pulley area? PCV issue?
    By neel2008 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2013, 02:14 PM
  3. GTP No Crank. Possible Passlock issue?
    By neel2008 in forum General Tech Discussion
    Last Post: 09-26-2011, 12:21 AM
  4. Intermediate steering shaft?
    By 04muscle in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 07:30 PM
