Thread: Grinding Noise
Results 1 to 5 of 5
  1. #1 Grinding Noise
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    This started last week or so. As I am driving I hear this metal on metal sound. I have been driving around listening to it and I have not been able to determine what seems to cause the noise to start.
    It will happen most often when I get back on the gas, but not all the time probably around 60% of the time. It will happen at just about any time except when I am cruising down the road at a steady speed.
    The noise doesn't stick around long as it comes and goes frequently. it happens often, but in short duration. It is not very loud as I cannot heat it with my windows up.
    Any ideas as to what is causing the problem and how to fix it?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: Grinding Noise
    SE Level Member Gorecki's Avatar
    Nov 2010
    Maryland, US
    Well from the limited description first thoughts are it's either brake related or maybe a wheel bearing starting to crap out.
    Where is it coming from?
    [TRADED] 2005 Grand Prix Silver
    K&N Air Filter, NGK TR55GP G-Power Plugs, Delphi OE Wires, Timken Bearings, Mobil 1 Synth ATF & Oil, Purolator PureOne Filter
  3. #3 Re: Grinding Noise
    Newnan, GA
    Thanks for the response, but I already figured out the problem.
    The noise was hard to track down, but after checking everything around the wheels, I decided to look under the hood. Took off the serpentine belt, and the noise went away. Turned out to be my A/C compressor trying to go out with a bang. I guess I am going to have to replace it after all.
  4. #4 Re: Grinding Noise
    Pennsylvania
    Probably the AC clutch, I bet the noise goes away when you turn the AC on, and comes back when you turn it off.
    Sport Edition Kv5 18x8
  5. #5 Re: Grinding Noise
    Newnan, GA
    A/C Hasn't held freon in years. The pulley is making the noise and has some play in it.
    Good news is that this is forcing me to finally fix this side of the A/C. I will fix the blend door later.
  1. grinding noise
    By BoostnBlackGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 11:28 AM
  2. Odd Noise - Clicking/Grinding
    By lespaul20 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2011, 10:30 PM
  3. grinding noise.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 01-03-2011, 11:03 AM
  4. grinding noise on turn
    By wade722 in forum Brakes/Suspension/Chassis
    Last Post: 08-26-2010, 06:15 PM
  5. new grinding noise
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 08:07 AM
