Thread: Magnasteer "Pulsing"
Results 1 to 15 of 15
  1. #1 Magnasteer "Pulsing"
    Never Never Land
    Any of you guys with Magnasteer ever felt pulsing when taking long corners? Such as a cloverleaf for an interstate on/off ramp? Basically gets tigther, looser, tighter, looser, as you take the corner.
    My Cadi does this and my Prix did the same thing as well. Both had Magnasteer. I believe it to be Magnasteer as it's desgined to vary the effort required to turn. So as you're taking the corner it's making it harder and easier to turn.
    Anybody felt this condition? Have any recomendations? I don't believe the pump to be the problem. Both cars had new tie rods so i'm doubting that too.
    The Boss Iceman6669's Avatar
    Jun 2011
    Mine asks kinda like that also...
    2011 F-150 Yote powered
  3. #3 Re: Magnasteer "Pulsing"
    I thought magnasteer turned off after you were at a certain speed.
  4. #4 Re: Magnasteer "Pulsing"
    Never Never Land
    No. Magnasteer is always active from my understanding. As you speed up it stiffens the steering. Below 15mph or whatever it makes it very loose so you can turn quick, like in a parking lot or whatever. I could be wrong though
  5. #5 Re: Magnasteer "Pulsing"
    Never Never Land
    Bumpy
  6. #6 Re: Magnasteer "Pulsing"
    Pennsylvania
    I know what you mean and my comp G does it too, it's very weak but like you said it gets tighter and looser very rapidly, but it's usually around faster turns.
    Sport Edition Kv5 18x8
  7. #7 Re: Magnasteer "Pulsing"
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    On most applications, the only input the control electronics uses for
    Magnasteer is the vehicle speed sensor. At zero mph, a negative current of
    approximately two to three amps flows to the Magnasteer coil. This causes the
    magnets to repel each other, which in turn allows more deflection in the torsion
    bar inside the spool valve assembly. This increases fluid flow through the spool
    valve to the steering gear for maximum power assist when it is needed most.
    As vehicle speed increases, current flow to the Magnasteer coil is gradually
    reduced. At about 45 mph, current flow to the coil hits zero and Magnasteer has
    no effect on the amount of power assist (which is determined only by the torsion
    bar and pump flow).
    Above 45 mph, the direction of current to the coil is reversed and continues
    to gradually increase up to a maximum of about three amps at 75 to 85 mph.
    Reversing the polarity of the coil causes the magnets to attract each other,
    which has the effect of stiffening the torsion bar. This reduces the amount of
    deflection in the torsion bar that normally occurs when the wheels are steered
    and causes an increase in steering effort for better road feel and high-speed
    steering stability.
  8. #8 Re: Magnasteer "Pulsing"
    Never Never Land
    Sooo....I wonder If I can crawl under there and disconnect the rack to test if that's the problem. Seems like it is but it doesn't hurt to make sure
  9. #9 Re: Magnasteer "Pulsing"
    Never Never Land
    I posted a similar thread over on the Cadi forum and they absolutely insist it's not Magnasteer at fault. What else could it be?
  10. #10 Re: Magnasteer "Pulsing"
    Texas
    Yep and I have always assumed it was the magnasteer in my car. I know leaving from a stop if I hold the brake and give the car a little gas it loosens the steering up.
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: Magnasteer "Pulsing"
    Never Never Land
    Well here's the thing. They're saying it's worn out components/bushings. But as said in the first post my 99 GTP did this exact same thing.
    It had new:
    LCA's with bushings and ball joints
    Sway links
    Tie rod ends
    Springs
    Struts
    Mounts
    Motor/trans mounts
    And rack
    Sooooo..how can worn out components be at fault when basically the whole suspension has been replaced? What's more is the GTP did it worse than the Cadi does, with all new parts.
  12. #12 Re: Magnasteer "Pulsing"
    Feb 2010
    Cleveland
    I would think to check for air in the lines on the power steering end, especially if someone replaced the rack in the car and didn't properly bleed the system it could be sucking in air occasionally. But with that you would also likely get a whining noise.
  13. #13 Re: Magnasteer "Pulsing"
    Never Never Land
    My Dad and I replaced the rack lol
    I suppose doing a P/S system flush is something to try.
  14. #14 Re: Magnasteer "Pulsing"
    did you crank the wheels lock to lock like 10 times after the new rack was installed? i know mine burped real nice when i did mine. it puked up all over the floor lol
    i feel no pulsing in mine at all. with the old one or the new to me used one.
  15. #15 Re: Magnasteer "Pulsing"
    Never Never Land
    Both cars were cranked lock to lock several times. It wouldn't hurt to try it again though.
  1. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  2. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
