Thread: EGR delete questions....
Results 1 to 19 of 19
  1. #1 EGR delete questions....
    Sep 2011
    Sioux City, IA
    I am pretty sure this has been covered somewhere, but i have done some searching and havent found much. Anyhow, the question is. If i remove, plugs open ports, and unplug the EGR will the car still run the same? I know there will be a check engine light, but besides that is that the only issue? BTW, its a 99 gtp
    Thanks guys!
  2. #2 Re: EGR delete questions....
    You will lose some cruising gas mileage
  3. #3 Re: EGR delete questions....
    Sep 2011
    Sioux City, IA
    Ok, that doesnt bother me so much. Thanks alot!
  4. #4 Re: EGR delete questions....
    SE Level Member ejechtion54's Avatar
    Ft. Wainwright
    Look on ZZperformance in the exhaust section and purchase the EGR block off plate, that will take care of the hippie EGR valve.
    Who ever said "Out with the old and in with the new."?
  5. #5 Re: EGR delete questions....
    Minnesota
    Quote Originally Posted by ejechtion54 View Post
    You need two. One for the rear exhaust manifold and one for the lower intake manifold. Should delete your EVAP while you are deleting stuff.
  6. #6 Re: EGR delete questions....
    Sep 2011
    Sioux City, IA
    haha! "hippie" Love it! So true tho! Ok, ill have to do that along with other maintenance things i am planning then!
  7. #7 Re: EGR delete questions....
    Omaha, NE
    Most people use RTV and a penny. It costs a lot less and works just as well.
  8. #8 Re: EGR delete questions....
    GT Level Member wlmrt6's Avatar
    Sterling
    will the car run any different tho
  9. #9 Re: EGR delete questions....
    if done properly, no.
  10. #10 Re: EGR delete questions....
    Buffalo
    Im sure it's better to not have hot exhaust gas in your intake . Kinda funny to see people run egr with a intercooler
    Imblocked at the lim with a penny and shut off via tuning. That why even if it's on to get the "ready" it won't dirty up my core.
  11. #11 Re: EGR delete questions....
    I run an EGR with my intercooler at times.
    And my e-test was damned clean too.
  12. #12 Re: EGR delete questions....
    Sterling
    well im doing an egr delete becuase the hose broke on my header install and i cant find the part anywhere around here. so what is the proper way to do it and i have to drive it a few days before i can get it tuned will it run ok or what
  13. #13 Re: EGR delete questions....
    which end? the bit from the EGR to LIM? if so, yards should have plenty of them. $10 at most.
  14. #14 Re: EGR delete questions....
    Sterling
    no yards around here for at least an hour drive. and its where it meets at the manifold.
  15. #15 Re: EGR delete questions....
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    can you explain how? please ... im curious
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  16. #16 Re: EGR delete questions....
    swift current,sask.
    Quote Originally Posted by biggt View Post
    Just like that except with pennies haha, hack the tubes off on both sides, use some high temp rtv and seal up both sides of the penny and bolt it back on and bam, .02 cent egr delete!!
  17. #17 Re: EGR delete questions....
    The Boss Iceman6669's Avatar
    Jun 2011
    All I did when I deleted the EGR was, unplug the egr, remove the two mounting nuts holding the egr down, then welded the two holes closed. I didn't even take the hoses off or the mounting bracket. Just welded the holes closed on the bracket.
  18. #18 Re: EGR delete questions....
    swift current,sask.
    Quote Originally Posted by Iceman6669 View Post
    Nothing wrong doing it that way, the engine bay just looks a lot prettier without all that emissions junk in it.
  19. #19 Re: EGR delete questions....
    Jul 2010
    Montreal
    will it set a code?? and usally what does it give??
  1. U Bend Delete & Resonator Delete
    By 9ordohz in forum General Tech Discussion
    Last Post: 10-23-2010, 10:57 AM
  2. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
