I know there has been several threads about this, but I have yet to pinpoint my exact trouble. I have a 2002 GT with 3.8L NA motor.
In the morning when engine is cold, or after sitting for a while, or if I immediately start the engine after shutting it off, the car starts and runs fine.
If the engine is warm after sitting for an hour or two, I turn the key and the engine starts and dies. I turn the key again and the car starts and runs normally. Sometimes if i suspect this will happen, I slightly depress the gas pedal while starting and it will start. Or I will turn the key to "run" for a few seconds before starting the car and it will start and stay running.
I'm thinking the fuel pressure regulator or MAF sensor. If the car is running and I unplug the MAF sensor, should it die?
