Thread: P2138 P1125 codes
Results 1 to 2 of 2
Threaded View
jlusleton P2138 P1125 codes 06-17-2011, 01:49 PM
gtpinsc Re: P2138 P1125 codes 09-23-2011, 05:35 PM
  1. #1 P2138 P1125 codes
    Jun 2011
    Lufkin
    2006 Grand Prix 3.8
    Reduced engine power notification appears in my display center, engine power definitely reduces, A/C blower slows down, car is sluggish and won't get up and go. This happens after I've been running a few minutes fairly consistently. Took my car by Autozone to have them hookup their code reader to tell me the codes. P2138 and P1125 are returned. I've read the descriptions and looked on the internet for information about these. I'm still not 100% sure where to start. Took the pedal assembly off. Based on what I've read the APP sensor is on the pedal assembly ? Was thinking it sounds like I need to replace that sensor. Looked at the wiring harness under the hood and really didn't see anywhere water is getting in. Did not do a hose test yet. Any help you guys could provide would be beneficial. Don't won't to spend a lot of money on this right now if I can keep from it. Saw the note from GM as well --> #07-06-04-019: Intermittent MIL/SES, DTC P2138 with Reduced Engine Power (Repair Instrument Panel (IP) to Body Harness Connector) - (Jun 21, 2007). Not sure where this harness is located. hhhheeeEEELLPP !!
    Last edited by jlusleton; 06-17-2011 at 01:52 PM. Reason: left out car info, typos
  1. Three codes.. what do you think?
    By NaturallySmashed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2011, 03:32 PM
  2. Help with SES codes
    By kstanko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2009, 09:27 AM
  3. Codes for A/C
    By ASTROALCHER in forum Introductions/Noob Questions
    Last Post: 09-08-2009, 12:49 PM
  4. 3 codes, what could it be?
    By spidamanSS in forum General Tech Discussion
    Last Post: 08-19-2008, 02:24 AM
  5. I got some codes
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2008, 07:41 AM
