Thread: Mass Air Flow Kills my car
Results 1 to 20 of 23
  1. #1 Mass Air Flow Kills my car
    GT Level Member rolyat's Avatar
    OKC
    Okay, so my car randomly decided not to start the other day. It died the second it started to run. At first I thought it was a passkey problem because my security had been blinking, but then I found out I had a maf code, so I unplugged the maf sensor and it started right up... figured the sensor was bad or shorted out so I bought a new one... same thing, dies the second it starts. Unplug it, runs great... Anyone ever had this problem? Or any solutions/things to try. Only reason I don't think it is still a passkey thing is because I thought that was more related to just shutting off the injectors, and after awhile of running the light will go out. So one time I waited for the light to go out before I plugged the MAF in... Still killed it.
    Any help is appreciated!
    2000 GTP: autolite 104's, 180 t-stat, shift kit, open cone spectre, 1.9 rockers, polished TB, ported blower, SD headers, zzp mps/3.4 pulley, 42.5lbs injectors, Reptile tune
  2. #2 Re: Mass Air Flow Kills my car
    OKC
    Also (+) wire had 13V, Ground wire had continuity (roughly 4-5 ohms), and the input voltage sensor wire had 5V. (Talking about the three wires that plug into the MAF)
  3. #3 Re: Mass Air Flow Kills my car
    GT Level Member thedudeSE's Avatar
    Rio grande city texas
    had the same problem, I changed the whole ignition switch. but maybe theres an easier fix.
    Dont walk around like your the king of the world..... Walk around like you dont give a fu** who the king of the world is.
    smgpfc epic member# 5
  4. #4 Re: Mass Air Flow Kills my car
    OKC
    The mass air flow sensor being unplugged let your car run too? New ignition switch... sounds like fun! lol
  5. #5 Re: Mass Air Flow Kills my car
    OKC
    Also guessing your security light was blinking?
  6. #6 Re: Mass Air Flow Kills my car
    GTP Level Member AjL227's Avatar
    IL
    Try disconnecting the battery, reconnect later and start it with cleared RAM.
    Its possible your MAF needs to be re-calibrated.
    Unplugging the MAF and starting the car just reverts to programmed tables.
    It's normal to run without the MAF, the car has to have a back up if the MAF fails.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  7. #7 Re: Mass Air Flow Kills my car
    OKC
    I know the car will run without the maf, thats why I unplugged it when I got the code, but it won't run optimally.
    I've disconnected the battery and tried again a couple of times. Also tried just taking out some ecm fuses... no luck.
    I did however look up how to reprogram the pk3 key, so the security light is gone and longer an issue to be considered!
  8. #8 Re: Mass Air Flow Kills my car
    OKC
    Oh, forgot to mention after the 40 minutes it took to reprogram the key... it started with the maf plugged in!?!?!? Then the kicker.... it just randomly died after idling for about 7 minutes, and went back to not even trying to start...
  9. #9 Re: Mass Air Flow Kills my car
    Wut uaz thuh cod?
  10. #10 Re: Mass Air Flow Kills my car
    OKC
    Wut uaz thuh cod?
    The code was a P0101
  11. #11 Re: Mass Air Flow Kills my car
    OKC
    Any more thoughts?... help is appreciated!
  12. #12 Re: Mass Air Flow Kills my car
    OKC
    Bump for some night time thoughts
  13. #13 Re: Mass Air Flow Kills my car
    OKC
    TTT
  14. #14 Re: Mass Air Flow Kills my car
    OKC
    Bump
  15. #15 Re: Mass Air Flow Kills my car
    OKC
    Bump... because I know for a fact more than 2 people on here have an idea as to what it could be...
  16. #16 Re: Mass Air Flow Kills my car
    OKC
    TTT
  17. #17 Re: Mass Air Flow Kills my car
    OKC
    Bump
  18. #18 Re: Mass Air Flow Kills my car
    GT Level Member sic6's Avatar
    san marcos, tx
    Is the o-ring possibly leaking at the MAF.
    That's alot of resistance on the ground circuit, should be somewhere near 1 or less ohm's.
    A high resistance ground can also cause that code to come on. I would check for any corrosion on the grnd side.
    97 GTP
  19. #19 Re: Mass Air Flow Kills my car
    OKC
    Okay, I will definitely check into the ground wire. Thanks for the help!
  20. #20 Re: Mass Air Flow Kills my car
    OKC
    Think there is a possibility I got a bad sensor? Does anyone know what the resistance should be between the terminals or which ones should be open loop?
  1. mass air flow sensor?
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2012, 10:35 AM
  2. mass air flow sensor?
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2011, 10:47 AM
  3. Which of the following is the MASS AIR FLOW sensor that I need on my 98 GTP?
    By vanels in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2010, 10:22 AM
  4. Mass Air Flow Sensor
    By msh227 in forum General Tech Discussion
    Last Post: 10-19-2010, 11:39 AM
