my front end has had a small vibration for some time,(very small) i was pinning it on bad tires and the alignment not being perfect. so now i have good tires up front all balanced, and since the new tires and alignment the vibration has gotten worse.
now when on the highway, giving it light gas, just enough to keep it moving, the driver side vibrates (feels like a tire out of balance) if i let off the gas it goes away, dont notice it when jumping on it at highway speeds. dont feel it driving around town either.
so i grabbed the d/s cv joint, and tried to move it, it moved up and down, and back and fourth. it moved just a bit, then i tried to push and pull it and it moved both ways. into the hub, and back into the trans. i dont know what is normal amount of movement here.
did same thing to pass side and it has less movement and seems tighter over all.
both cv boots are intact and no grease anywhere.
im thinking i need a new axle but figured id ask the guys who know.
