Thread: Fuel rail pressure relief fitting?
Results 1 to 6 of 6
  1. #1 Fuel rail pressure relief fitting?
    Minnesota
    I have stock modded fuel rails from ZZP. I want to put a fuel pressure gauge on them. Does anyone know the exact size of the pressure relief fitting? I plan on putting a 45 degree adapter on it and then adding the gauge.
  2. #2 Re: Fuel rail pressure relief fitting?
    I belive it's listed on Aeroforces website. Otherwise, I'm worthless to you.
  3. #3 Re: Fuel rail pressure relief fitting?
    Minnesota
    I will check that out. If nothing else I will have to E-mail ZZP and ask what size their adapters are.
  4. #4 Re: Fuel rail pressure relief fitting?
    Minnesota
    Looks like I stumped even ZZP with this one. lol
    Anyone know the size? I guess I can buy and test fit different adapters but I don't want to.
    I know that the gauge I want to buy has a 1/8" NPT fitting but need to know what the other side of the 45 degree adapter should be.
  5. #5 Re: Fuel rail pressure relief fitting?
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  6. #6 Re: Fuel rail pressure relief fitting?
    Minnesota
    Yeah its -04an on the fuel rail.
  1. Fuel rail pressure?
    By GINOSGTP in forum General Tech Discussion
    Last Post: 05-06-2009, 12:52 PM
  2. Trans pressure test port fitting
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-17-2008, 11:01 AM
