Thread: 2002 GT starts and dies engine warm
Results 1 to 14 of 14
  1. #1 2002 GT starts and dies engine warm
    Aug 2011
    Bismarck, ND
    I know there has been several threads about this, but I have yet to pinpoint my exact trouble. I have a 2002 GT with 3.8L NA motor.
    In the morning when engine is cold, or after sitting for a while, or if I immediately start the engine after shutting it off, the car starts and runs fine.
    If the engine is warm after sitting for an hour or two, I turn the key and the engine starts and dies. I turn the key again and the car starts and runs normally. Sometimes if i suspect this will happen, I slightly depress the gas pedal while starting and it will start. Or I will turn the key to "run" for a few seconds before starting the car and it will start and stay running.
    I'm thinking the fuel pressure regulator or MAF sensor. If the car is running and I unplug the MAF sensor, should it die?
    2002 Grand Prix GT 40th Anniversary Edition
  2. #2 Re: 2002 GT starts and dies engine warm
    St. Louis
    Might be a sticky IAC valve. And don't unplug the MAF with the car running. You want to try this test BEFORE you start it and see if it makes a difference.
  3. #3 Re: 2002 GT starts and dies engine warm
    Sep 2011
    Canada
    Do you have a check engine light on? If so get it scanned for the code.
  4. #4 Re: 2002 GT starts and dies engine warm
    You should not plug or unplug sensors with the engine running. It's odd about maf unplugging, because it takes our pcms a moment to learn. I always have to use some throttle and keep an engine running for a minute after starting with an unplugged maf. 2nd and 3rd start unplugged, it usually runs pretty good.
  5. #5 Re: 2002 GT starts and dies engine warm
    Aug 2011
    Bismarck, ND
    No SES light. Car runs good, just quirky when starting.
  6. #6 Re: 2002 GT starts and dies engine warm
    Florida
    I have the same problem lol. I havent done anything yet to figure it out but im sure its somethin easy like the IAC or dirty MAF.
  7. #7 Re: 2002 GT starts and dies engine warm
    Aug 2011
    Bismarck, ND
    This morning when I started the car, it was 29 degrees, and it acted the same way.
  8. #8 Re: 2002 GT starts and dies engine warm
    What have you done to try and remedy the issue? It's not really clear from reading the thread.
  9. #9 Re: 2002 GT starts and dies engine warm
    Aug 2011
    Bismarck, ND
    Haven't done anything. Looking for suggestions.
  10. #10 Re: 2002 GT starts and dies engine warm
    Sep 2011
    Canada
    Well, so far here's what I would check: IAC, MAF sensor, IAT, and coolant temp sensor.
  11. #11 Re: 2002 GT starts and dies engine warm
    Aug 2011
    Bismarck, ND
    Thanks for the input!
  12. #12 Re: 2002 GT starts and dies engine warm
    St Louis, MO
    Had this happen last year during the early spring. Ended up being a bad spark plug. Whoever did the plugs before we bought the car got lazy or didn't have the right extension, and left #6 in there. It would fire up then immediately die. Not every time, but usually on a cold start.
  13. #13 Re: 2002 GT starts and dies engine warm
    Florida
    ^ It could be spark plugs or wires, since I changed my plugs and wires the other day my similar problem hasnt came back and i remember when i did my plog when i pulled the wires one of the wires had the metal piece still stuck on the plug. After that point thats when i had the cold start die issue. Now no more.
  14. #14 Re: 2002 GT starts and dies engine warm
    Aug 2011
    Bismarck, ND
    After some checking, I pulled the vacuum line off the fuel pressure regulator and found gas in it, so it appears the regulator is bad. I'll try replacing that first.
  1. GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    By 93Chewbacca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 09:38 PM
  2. Starts then dies warm
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2010, 07:02 PM
  3. PLEASE HELP!! car starts then dies
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2010, 01:32 AM
  4. Starts then Dies!
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-29-2010, 08:42 AM
  5. 04 starts then dies
    By oldtruckluvr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 08:09 PM
