Thread: my 0-60
Results 1 to 8 of 8
  1. #1 my 0-60
    GT Level Member natethegreat's Avatar
    Brookings, SD
    heres my 0-60
    0-60 02 grand prix gt - YouTube
    but im confused, when you guys launch do you just hold the brake and press the accelorater then release the brake and punch it? thats what i did, ive only done it once but it seems if you did it alot it wouldnt be good for your tranny? oh btw, its kinda slow haha
  2. #2 Re: my 0-60
    West Side Michigan
    To get the best launch, you want to minimize wheel spin.. so just gently ease into the throttle and then floor it. It'll take a couple tries to figure out when you can floor it or how hard you can take off from start.
  3. #3 Re: my 0-60
    Brookings, SD
    oh ok, yeah that makes sense, ill have to practice more, so do you rev it up? or do go from an idle to easing into it?
  4. #4 Re: my 0-60
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Since you have a GT, you can probably give it about 3/4 throttle till you get to like 10mph and then step on it all the way. I wouldn't hold the brake and rev up, its FWD, not all wheel drive, all thats going to do is make you spin more. Like Nawarkk said, play around and try to minimize your wheelspin.
  5. #5 Re: my 0-60
    May 2008
    Winnipeg, MB
    also if you have a traction control button, turn that off first
    2007 Pontiac Grand Prix
  6. #6 Re: my 0-60
    Florida
    Why does yours shift at like 5400-5500 rpm? mine gets to like 6000.Should at least get to 5800.
  7. #7 Re: my 0-60
    Brookings, SD
    i let off the pedal on purpose to make it shift earlier, i wasnt sure if i should have it getting up above 6000
  8. #8 Re: my 0-60
    Florida
    Well considering your stock theres no problems with letting it get to its max shift point.That will also knock your 0-60 down maybe half a second.
