Thread: obd 2 port not working
Results 1 to 7 of 7
  1. #1 obd 2 port not working
    my friends got a 05 chevy 3500 dump truck, the engine light is on, so we went to get it scanned and it wont power up the scanner, tried 2 different scanners too, checked fuses, didn't find any thing but the cigg lighter was out. swapped that fuse.
    any ideas what would make it not work? im at a loss here, never had this problem before.
  2. #2 Re: obd 2 port not working
    Omaha, NE
    Bad wiring to the harness?
  3. #3 Re: obd 2 port not working
    Grand Rapids, MI
    perhaps the computer itself is bad? i mean if the codes are stored there but can't be accessed it could be a problem with the computer. just guessin here.
  4. #4 Re: obd 2 port not working
    Omaha, NE
    If its an 05, it probably wouldn't start if the computer was bad.
  5. #5 Re: obd 2 port not working
    it runs ok, it does have a rough idle, that's about it, its only got 35,000 on it too, but then again its always loaded to the balls, and towing a heavy trailer all day, every day.
    its running like it needs a tune up, but that's supposed to be 65,000 miles away, but under the conditions it lives under, who knows. poor truck works hard.
  6. #6 Re: obd 2 port not working
    Donating Users
    South Deerfield, MA
    Check and see if the lighter fuse is blown again. I have worked on other GM products that share the same fuse for the OBD II port and the lighter. Maybe the new fuse you put in blew again right away due to a short.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  7. #7 Re: obd 2 port not working
    Quote Originally Posted by Silver GTP View Post
    the lighter now works, but like you say, it could share a fuse and not have it marked. he gonna have to go back and see if it works or not. if no ill look at the wires as far as i can get to/see, if i cant find anything its off to the shop for him.
  1. AUX Port...?
    By Jcal1120 in forum Audio, Security & Visual Electronics
    Last Post: 04-12-2011, 06:53 PM
  2. My S/C Port
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2009, 01:54 PM
  3. How to port your m90.
    By minichopper6hp in forum How To Write-Ups/Tech Tips
    Last Post: 09-03-2009, 04:32 PM
  4. Port and polish
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2008, 02:57 AM
  5. Port my LIM???
    Last Post: 09-16-2008, 09:50 PM
