Thread: Sway Bar
Results 1 to 20 of 33
  1. #1 Sway Bar
    The Boss Iceman6669's Avatar
    Jun 2011
    Soo i was doing my brakes the other day and noticed that part of my sway bar on my drivers side is busted. I have a few buddies with GP's and they have all had the same problem. I don't know if it is a common thing or not but any way my question is Since only the lower part of the connection is busted how huge of a deal is it that I get it fixed RIGHT NOW.... I plan on doing it when I do my struts and stuff but thats not going to be for a couple of weeks..
  2. #2 Re: Sway Bar
    michigan
    Not a huge deal, ur handling is going to be less up front with out that doing its job.
  3. #3 Re: Sway Bar
    Jun 2011
    Thats what I thought.. the funny thing is I could tell something was wrong because of the way it felt in the steering wheel. So as I was doing my brakes I was doing a check of things like the wheel bearings, tie rods, Ball joints, cv axels, Sway bar DAM IT.... There was the problem.
  4. #4 Re: Sway Bar
    St. Louis
    Time for a new Dorman bar from RockAuto. 34mm SOLID bar. Just may be a small PITA to get in there but well worth it. Should come w/ endlinks as well.
  5. #5 Re: Sway Bar
    Jun 2011
    MY buddy just put that one in on his and said it wasn't too bad.
  6. #6 Re: Sway Bar
    michigan
    I got the gmpp one, came with stb and rear for $132, thought it was a hell of a deal seeing autozone wanted 120 just for the doorman front. Come to find out its hollow, and I believe somehow I installed it upside down, cuz its rubbing on on my dp.
    Edit: just got done flipping mine so its correct now. Took about 1 1/2 hrs. With hand tools and floor jack.
  7. #7 Re: Sway Bar
    you could unhook the other side and just drive it for a while if you wanted to.
  8. #8 Re: Sway Bar
    Feb 2010
    TN
    Easiest way to replace it unhook tie rod end from one side only push wheel all teh way forward unbolt bar pull out slide new one in takes 20 min
  9. #9 Re: Sway Bar
    Jun 2011
    Detroit, MI
    Quote Originally Posted by Logan541 View Post
    Thats a lie, you can't just "slide it in"...
    It took me two and a half hours to get the Dorman in, and it made a difference over having no sway bar like I had before.
    Its just that it is like a 40 lb oblong tube, and you cant rotate it easily, and the steering arms get in the way and bleghhhh but you should do it. It's $100 at advance auto for the kit.
    iLoveSpade
  10. #10 Re: Sway Bar
    I figure it's easier to drop the rear subframe but that's the only way i've done it so i'm not sure how the other way is.
  11. #11 Re: Sway Bar
    Denver
    A local AAMCO shop charged me $50 for a tie-bar install (Dorman rod supplied by me).
    Since they have a lift, it's easy for them.
    On your back with stands and a floorjack, you will be fighting it for several hours.
    $50, for me, was a no-brainer.
    Also, my sway bar end had also cracked.
    The new Dorman (33mm OD solid) greatly improved body roll.
  12. #12 Re: Sway Bar
    Donating Users
    South Deerfield, MA
    Quote Originally Posted by Hippo Machine View Post
    Guess I'll tell the same lie then. Mine went in from the side in far less than 2 1/2 hours.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  13. #13 Re: Sway Bar
    Jun 2011
    Detroit, MI
    Quote Originally Posted by Silver GTP View Post
    Guess you will, because I was talking about the Dorman, not a hollow tube...
    iLoveSpade
  14. #14 Re: Sway Bar
    I did mine in about an hour no problem.
  15. #15 Re: Sway Bar
    Donating Users
    South Deerfield, MA
    Guess you will, because I was talking about the Dorman, not a flimsy hollow tube...
    lol. So, since they are the same dimensions, are you saying the GMPP bar bends like a rubber band to go in easier? Please elaborate on how your Dorman bar goes in harder than a GMPP bar does.
  16. #16 Re: Sway Bar
    SE Level Member iamsam2010's Avatar
    Sep 2011
    Cullman, Alabama, United States
    if i replace mine should i go ahead and buy the reinforced one that i keep seeing on slp performance and crap that says its better than stock parts or w/e....i think the dimensions are a little stranger than factory but supposedly better
    not sure
    ~D@V!$~
  17. #17 Re: Sway Bar
    Denver
    I think he's saying it's way lighter and thus easier to install (similar to how aluminum heads are faster to install than cast heads etc).
    I can say that laying on by back, crouching down, that manhandling the solid Dorman sway brace is not somthing I would like to mess with. With little leverage, so close to the ground, it would be a bastard as it weighs a ton.
  18. #18 Re: Sway Bar
    Jun 2011
    Detroit, MI
    lol. Please elaborate on how your Dorman bar goes in harder than a GMPP bar does.
    Umm a hollow tube is much lighter than a solid tube.
    iLoveSpade
  19. #19 Re: Sway Bar
    Donating Users
    South Deerfield, MA
    Quote Originally Posted by iamsam2010 View Post
    not sure
    Probably the best option for you would be the Dorman bar that is being discussed. It is readily available, a cheap price and an upgrade over stock.
    Dorman sway bar 927-100 21.7 lbs. I don't want to discriminate against anybody who's muscularly challenged, but I don't see how that weight would add difficulty to the install.
  20. #20 Re: Sway Bar
    Ocala, FL
    Maybe you need to bench press with it for a few weeks before you install it?
  1. Sway bar
    By BuckyKatt in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2010, 09:24 PM
  2. sway bar
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 02:38 PM
  3. Sway bar Help
    By Fivefingerdeathpunch in forum Introductions/Noob Questions
    Last Post: 09-24-2009, 03:40 PM
  4. Sway bar?
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 06:11 PM
  5. sway bar.
    By justwhisen in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2008, 02:53 AM
