Thread: Need 255 fuel pump info
Results 1 to 9 of 9
91z Need 255 fuel pump info 08-17-2011, 02:53 PM
Pure2sin Re: Need 255 fuel pump info 08-17-2011, 05:03 PM
91z Re: Need 255 fuel pump info 08-17-2011, 05:34 PM
TheOtherNick Re: Need 255 fuel pump info 08-17-2011, 05:53 PM
91z Re: Need 255 fuel pump info 09-08-2011, 03:14 PM
darkhorizon Re: Need 255 fuel pump info 09-08-2011, 03:18 PM
Pure2sin Re: Need 255 fuel pump info 09-08-2011, 08:56 PM
91z Re: Need 255 fuel pump info 09-09-2011, 08:11 AM
Pure2sin Re: Need 255 fuel pump info 09-09-2011, 05:41 PM
  1. #1 Need 255 fuel pump info
    Mn
    I have a 2004 gtp comp g and need to upgrade the pump so I can convert it to e85. Im confused on if it is a venturti pump or not and where and what brand would be the best to get. Thanks for any info!
  2. #2 Re: Need 255 fuel pump info
    Minnesota
  3. #3 Re: Need 255 fuel pump info
    Mn
    I was looking at that one, but when you type in my car it says not compatible? And still dont know if its a venturi style pump stock?
  4. #4 Re: Need 255 fuel pump info
    Charles City, IA
    Yours I would think would be a ventri like the 01-03 gps, but you also have a semi returnless system, so I would talk to one of the vendors and check your options.
    SMGPFC Two Nipple General
  5. #5 Re: Need 255 fuel pump info
    Mn
    So far I havent found any good info about what type of pump I have? Called a few parts places and got nothing other than they want to sell me a new assembly?
  6. #6 Re: Need 255 fuel pump info
    Feb 2009
    flintnasty MI
    Quote Originally Posted by 91z View Post
    Email zzp.
  7. #7 Re: Need 255 fuel pump info
    Minnesota
    ZZ Performance
    "97-00 supercharged cars will want the venturi style pump, the 01+ supercharged and 97+ NA fuel canisters will not need the Venturi style pump."
    People have compaired ZZPs pump to Ebay pumps like I listed above and they came in basically the same box but ZZP doesn't off the lifetime warranty.
    You could get a non modded Walbro pump or contact that company I linked above. They have both venturi and non venturi pumps.
    IIRC Racetronix takes Walbro pumps and modifies them to have a venturi and opens them up a little.<--That is the pump PRJ sells.
  8. #8 Re: Need 255 fuel pump info
    Mn
    I think i am going to get the venturi style pump just to be safe, and to not go through all the work of pulling the pump to check. If its not I think I should be able to plug the venturi port and it will work fine. Thanks for all the info!
  9. #9 Re: Need 255 fuel pump info
    Minnesota
    You have a non venturi pump in your car. I don't know if you can just not plug the venturi in and make it work on a venturi pump.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  4. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
