Thread: Fuel Line Connectors
Results 1 to 12 of 12
  1. #1 Fuel Line Connectors
    GT Level Member cojo's Avatar
    Flint Michigan
    Are both of the the Fuel Line Connectors 3/8s??
    The one on the right is leaking and eating up my paint, and I believe this is what i need to replace here
  2. #2 Re: Fuel Line Connectors
    i do believe that is what you need. Not pos though as i've never had to replace one.
  3. #3 Re: Fuel Line Connectors
    Flint Michigan
    i think so too, but the thing is that a 3/8 disconnect did work on right one, but did on the left... And the right one does look a lil bigger.
  4. #4 Re: Fuel Line Connectors
    Supply is 3/8
    Return is 5/16
  5. #5 Re: Fuel Line Connectors
    Flint Michigan
    Supply is 3/8
    Return is 5/16
    Left one (referring to me pic) is the return - 5/16
    right is supply - 3/8
    Correct?
  6. #6 Re: Fuel Line Connectors
    Yes, the larger line is 3/8 and the smaller line is 5/16.
  7. #7 Re: Fuel Line Connectors
    any one have the part # for the O rings for a 98 regal fuel lines? the ones on top of the sc. mine has started to drip too, and after seeing a gp burning in a lot last week, im getting a bit nervous.
    and do i need a set of fuel line disconnects to open the fuel line or is there a free way to pop open the connection? i seem to remember popping them open with out one before,(on other cars) but im unsure if these will open with out the special tool you slide over the line and into the connection.
  8. #8 Re: Fuel Line Connectors
    GT Level Member sic6's Avatar
    san marcos, tx
    i have never been able to successfully locate replacement o-rings. It was cheaper and faster to replace the fuel line with dorman's 3/8" quick disconnect line. It was 20.00 at my local auto parts.
    Yes you will need them,most fuel disconnect tools are cheap as well. 10 bucks for the plastic set at vatozone.
    97 GTP
  9. #9 Re: Fuel Line Connectors
    i came across a how to write up some time ago here and cant find it, not even google will help this time, i know replacements are out there.
  10. #10 Re: Fuel Line Connectors
    Oct 2011
    San Jose, CA
    Scottydoggs, did you find replacement o-rings?
  11. #11 Re: Fuel Line Connectors
    i haven't found the write up for it again, it had the right size and all to get, napa told me to take the O rings out and bring them to him to match up, well thats not going to work for. what if they dont have what i need and the old ones break or some crap, the search continues lol
  12. #12 Re: Fuel Line Connectors
    Ocala, FL
    I did it with like 3 screwdrivers, and no special tool.
    check out this thread, which I just made a post in:
    http://www.grandprixforums.net/could...tml#post655877
  1. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  2. will a 97-03 L67 SC fuel line fit on my 97 GT L36?
    By mandingo in forum General Tech Discussion
    Last Post: 08-07-2010, 02:53 AM
  3. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  4. Fuel line disconnet
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2009, 08:22 AM
  5. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
