Thread: Misfire on cylinder 3 and 4
Results 1 to 4 of 4
  1. #1 Misfire on cylinder 3 and 4
    Sep 2011
    United States
    Anybody have trouble with a 2004 supercharged grand prix with a misfire in cylinder 3 and 4. Especially under heavy load with pedal 3/4 to all the way down.
    Check engine light is blinking. Both spark plugs showing misfire.
    The catalytic converter does need to be replaced.
    Compression is good.
    You can tell a little rough miss during idle but no codes during idle.
    Anybody have this trouble before?
  2. #2 re: Misfire on cylinder 3 and 4
    Have you replaced the plugs and wires? Or the coils? Or the ICM?
    Just because your converter is good doesn't mean squat...get a tune-up if you haven't done one...oil/oil filter/PCV valve, etc.
    Clear the code from the PCM.
    Then enjoy your car not hating you.
    Also, welcome to the site...
  3. #3 re: Misfire on cylinder 3 and 4
    Replace your cat before you hurt the motor.
    The likely reason behind 3 and 4 misfiring is they are the two middle cylinders in the front and rear. Therefore naturally they tend to run hotter than the other 4 cylinders.
    Now add back pressure of a bad catalytic and you heat them up even more leading to misfires, probably knock and potentially damage.
  4. #4 re: Misfire on cylinder 3 and 4
    I thought it said the coverter was GOOD.
    Nevermind.
  1. Cylinder #2 misfire
    By EJOUIE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:38 PM
  2. Cylinder #3 misfire
    By Newby101 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-15-2011, 03:02 PM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. Cylinder 3 Misfire
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2010, 11:24 PM
