Thread: Looky at my new tool
Results 1 to 12 of 12
  1. #1 Looky at my new tool
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Bought it from advanced this morning for $212 with some 15% off deal they are having. Not bad. Anyways i got it because i will be tackling taking my engine out this weekend. No more taking my Impy to the mechanics and spending Nearly $1000s just for engine removal and replacements. Other than the ***** bolt in the back (which i have my extensions ready for it, will i run into problems? Thanks for any responds guys.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Looky what i just put together
    Upon re-install, leave the ***** bolt out, that way you never have to deal with it again.
  3. #3 Re: Looky what i just put together
    You broketed it?
  4. #4 Re: Looky what i just put together
    Go to Sears. Buy an extension that's 24 or 36" in length. Problem solved for the rest of your life. Put the bolt back in..it's not even tough if you have the right tools.
  5. #5 Re: Looky at my new tool
    Bowie, MD
    Ok cool was just about to ask if it was safe to leave the bolt out untill i seen your post dyno lol.
    @blue no it isnt broke i want to remove it because i have a slight ticking ever since the engine went in and goes away when the engine warms up.
  6. #6 Re: Looky at my new tool
    Charles City, IA
    So how about you just pull the intake and replace the lifters. Also those hoists are champs I have the same one It will lift out a 7.3l diesel on the 1/2 mark.
    SMGPFC Two Nipple General
  7. #7 Re: Looky at my new tool
    Bowie, MD
    yes indeed. I just used it to take my friends new engine out out of a pick up truck with ease. I will check my lifters also.
  8. #8 Re: Looky at my new tool
    Bowie, MD
    So i started to take apart my engine and removing bolts by following this guide http://www.grandprixforums.net/how-p...yle-47220.html. I get to step 13 aka the ***** bolt and mine is missing. I guess the shop that replaced my motor back in january didnt put it back in. Is this good or bad?
  9. #9 Re: Looky at my new tool
    What is the ***** bolt?
  10. #10 Re: Looky at my new tool
    Omaha, NE
    13. Look along the back of the engine toward the transmission, see the 18mm bolt. Using the long extensions and a deep 18mm socket, remove that bolt. The long socket will hold the bolt.
    I've heard that this bolt isn't necessary, but I could be wrong.
  11. #11 Re: Looky at my new tool
    Bowie, MD
    Well the car has been good since the engine went in January of this year and that bolt seemed to have not been in it. Guess i shouldn't worry then. I just have the 4 bolts Holding the engine to the trans inside the engine bay , flex plate bolts, and rear sd header bolts to remove and ill be pulling it out tomorrow morning.
  12. #12 Re: Looky at my new tool
    Bowie, MD
    smh so i pulled my engine this morning and what do i see???
    Yep thats right a cracked flex plate. So me thinking my engine blew was over exaggerated and wrong. Im kinda of glad and sad. Anyways I put my spare engine in and swapped parts and will be finishing up tomorrow along with my friends car. This engine will be put to the side so i can get a stronger flex plate, bolts, and work on it.
  1. Looky What I Found: Intrax!
    By SDGTP99 in forum Off Topic Discussion
    Last Post: 08-30-2011, 03:34 PM
  2. looky:D what a girl can do ;)
    By beckys2000gt in forum Visual/Body Modifications
    Last Post: 07-06-2010, 11:31 PM
  3. looky what I found...
    By UR LOSN in forum Off Topic Discussion
    Last Post: 06-14-2009, 05:01 AM
  4. need tool
    By badbrad in forum General Tech Discussion
    Last Post: 05-10-2009, 01:03 AM
  5. looky what i got
    By Bio248 in forum Visual/Body Modifications
    Last Post: 03-22-2009, 11:32 PM
