Thread: Air Conditioning
Results 1 to 3 of 3
  1. #1 Air Conditioning
    Aug 2011
    Edmonton
    I have a 2000 GTP supercharged car. The A/C is dual control and has been working fine so far until one day it went warm on the drivers side and stayed cool on the passenger side. By the time I went to the mechanic both sides were warm. I had it recharged which worked perfectly for 5 days when the whole system went warm again. The heat workes perfectly. He checked for leaks but couldn't find any saying it was the evaporator that was leaking. I am REALLY hoping this is not the case and maybe it's a sensor? I did have a sensor replaced years ago. The other thing that might have affected it was I had water pooling on my passenger side which could have effected the system. There are no codes, no warning lights and the fuses are fine.
    Any ideas?
  2. #2 Re: Air Conditioning
    I'd bet it's the compressor they leak when they get old and don't really show any signs of leaking.
  3. #3 Re: Air Conditioning
    when you have a a/c leak there will be a oily dark slime at the leak area. (or be really dirty looking) check fittings from hose to pipe and at the sensors where they screw in, any where a connection is.
    if it went warm, you recharged it and 5 days later its warm again, you have a leak.
  1. 98 Air Conditioning
    By sofine21 in forum General Tech Discussion
    Last Post: 08-28-2011, 12:03 PM
  2. Air conditioning fan won't turn off
    By RegorHtims in forum General Tech Discussion
    Last Post: 06-28-2011, 10:37 PM
  3. Air conditioning not turning on
    By lcamaya in forum Introductions/Noob Questions
    Last Post: 06-11-2011, 11:09 AM
  4. air conditioning
    By handirifle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2009, 04:00 AM
  5. Air conditioning
    Last Post: 06-23-2009, 11:33 AM
