Thread: Squealing noise when turning on A/C
Results 1 to 7 of 7
  1. #1 Squealing noise when turning on A/C
    Aug 2011
    Clark NJ
    I am new to these forums and have an issue with my 03 GPGT. Recently when turning on the A/C it makes a squealing noise coming from above the front passenger side almost above the glove box. Today, this noise didn't happen and there is no air flow from the A/C. When driving this morning I hit a bump and the A/C came on then turned off again. Does anyone know what this can be caused by and how to fix it? Thanks.
  2. #2 Re: Squealing noise when turning on A/C
    Michigan
    I can't be for sure but sounds like what happened to me a few years ago. Mine would squeal and became louder when I hit the gas then one day it stopped working. I never checked it out until this year because I assumed it would be an expensive fix. My compressor went bad and from what I read the squealing is a sign of it on its way out. With a baby this year I figured I'd spend a little money a try to get it working. Bought a compressor off ebay from a guy who rebuilds them for about 80 shipped free, also bought an accumulator and orifice tube(but didnt put it in because looked like a pain and was told because it didn't blow up it wasn't absolutely necessary) Its possible that the compressor has a leak somewhere, I had no leaks anywhere else so basically my compressor failed. Fixed mine for around 150, compressor, accumulator, ac oil and some R34, pretty easy to do if that's whats happening with you. Oh and my dad was able to borrow a vacuum pump which is needed to draw a vac on the system.
  3. #3 Re: Squealing noise when turning on A/C
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Probably the blower motor from where you describe the squealing noise. It usually squeals when you first turn on the fan and then goes away. This is a sign that the motor is on its way out.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  4. #4 Re: Squealing noise when turning on A/C
    X2^^^^^^^^^
  5. #5 Re: Squealing noise when turning on A/C
    Never Never Land
    The squeeling noise is the blower motor. It cutting in and out is the resistor or a loose connection.
  6. #6 Re: Squealing noise when turning on A/C
    Charles City, IA
    Sounds like you need a blower motor.
    SMGPFC Two Nipple General
  7. #7 Re: Squealing noise when turning on A/C
    Chilliwack BC
    or there is something alive inside the motor squealing for help.....
  1. squealing noise from crank pulley area? PCV issue?
    By neel2008 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-31-2013, 02:14 PM
  2. Odd problem, noise only when turning right.
    By BmoreDrew in forum General Tech Discussion
    Last Post: 04-13-2011, 09:02 PM
  3. Possible Trans Noise? Only when turning right?
    By BmoreDrew in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-13-2011, 06:44 AM
  4. squealing noise
    By Mr Biegz in forum Off Topic Discussion
    Last Post: 11-20-2010, 08:02 PM
  5. Squealing Noise
    By eXceL(FAM) in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2008, 07:49 PM
