Thread: HUB nut sizes
Results 1 to 19 of 19
RichCresci HUB nut sizes 07-09-2008, 09:32 PM
BADAZGTP Re: HUB nut sizes 07-09-2008, 09:59 PM
archemedes Re: HUB nut sizes 07-09-2008, 10:13 PM
BADAZGTP Re: HUB nut sizes 07-09-2008, 10:15 PM
DanGTP Re: HUB nut sizes 07-09-2008, 10:28 PM
archemedes Re: HUB nut sizes 07-09-2008, 10:30 PM
BADAZGTP Re: HUB nut sizes 07-09-2008, 10:30 PM
GeddyLee Re: HUB nut sizes 07-10-2008, 12:35 AM
stlmo_gtp Re: HUB nut sizes 07-10-2008, 12:44 AM
RichCresci Re: HUB nut sizes 07-10-2008, 09:27 AM
BADAZGTP Re: HUB nut sizes 07-10-2008, 09:42 AM
Zef_66 Re: HUB nut sizes 07-10-2008, 10:29 AM
Abrasive Re: HUB nut sizes 07-14-2008, 08:23 PM
Guest Re: HUB nut sizes 07-14-2008, 08:27 PM
_nick_ Re: HUB nut sizes 07-16-2008, 11:20 PM
Abrasive Re: HUB nut sizes 07-26-2008, 11:57 PM
Guest Re: HUB nut sizes 07-27-2008, 12:28 PM
  1. #1 HUB nut sizes
    SE Level Member RichCresci's Avatar
    Jul 2008
    I need to change my hub tomorrow and know i don't have a socket big enough for the center nut, Anyone know the size? thanks, Rich
  2. #2 Re: HUB nut sizes
    Apr 2008
    Chillin at the Beach , VA
    It is either a 35mm or 36mm socket. I want to say 36mm, but if you don't have either one, you can rent them at autozone and get your money back when you return them. I would pick up both just incase. And also a torque wrench if you don't have one. What is the year of your GP?
  3. #3 Re: HUB nut sizes
    Saraland Alabama
    it's a 36mm
  4. #4 Re: HUB nut sizes
    Apr 2008
    Quote Originally Posted by archemedes View Post
    it's a 36mm
    OH! I knew that, I was just testing you.lol!!!!
  5. #5 Re: HUB nut sizes
    Feb 2008
    my '97 uses a 35mm and that happens to be one of the sized Autozone doesn't rent out. Oh well. At least I will never have to go rent one if I have to change out hubs.
  6. #6 Re: HUB nut sizes
    Saraland Alabama
    Quote Originally Posted by DanGTP View Post
    my '97 is a 36mm (the socket is under 10 bucks though)
  7. #7 Re: HUB nut sizes
    Feb 2008
    That's not fair!
  8. #8 Re: HUB nut sizes
    Apr 2008
    Thanks for the extra input.
  9. #9 Re: HUB nut sizes
    St. Louis Mo.
    My O3 is a 36mm
    James Shafer
    St. Louis MO
  10. #10 Re: HUB nut sizes
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    i have a 97 a 36mm fits it well
  11. #11 Re: HUB nut sizes
    Jul 2008
    i have a 99 gtp sedan lol, is it 35 or 36?
  12. #12 Re: HUB nut sizes
    Apr 2008
    Yeh, it'll be one of the two and I think the torque specs are about 150 ftlbs. It's in the Haynes manual if you have one.
  13. #13 Re: HUB nut sizes
    PA
    I have a 97 GTP and I have one 36 mm and one 34mm.
    I believe that stock they all had 36 mm nuts on them. Aftermarket hubs that provide their own nuts can be almost any size. That is how I got one 34mm. And I assume others would get the 35mm.
    2001 GSE
  14. #14 Re: HUB nut sizes
    Odessa, MO
    Weird, had to take off mine Saturday for the CV rebuild..... 33mm, and that was actually a little loose.
  15. #15 Re: HUB nut sizes
    TDCRacing
    Guest
    Quote Originally Posted by Abrasive View Post
    Again???? man brian wasent kidding.
  16. #16 Re: HUB nut sizes
    I used a 36 mm for my olds intrigue, but it was loose...got the job done though just have to keep in on the nut straight..should have been a 35mm but they are a rare size
  17. #17 Re: HUB nut sizes
    Odessa, MO
    Quote Originally Posted by TDCRacing View Post
    Looked as though something actually got kicked up and punctured a hole in the boot. Definitely not from normal wear, but at least I caught it early. Also, I don't know what Brian's been telling you and probably don't want to. LOL!
  18. #18 Re: HUB nut sizes
    TDCRacing
    Guest
    LOL
  1. m90 bolt sizes!
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2008, 03:37 PM
  2. stock speaker sizes
    By hotshot in forum Audio, Security & Visual Electronics
    Last Post: 06-16-2008, 06:06 AM
  3. injectors sizes
    By suprchrgd in forum Off Topic Discussion
    Last Post: 01-22-2008, 07:20 PM
