Some of you know that I went through a bunch of built up transmissions. Let me kick out some basic info first and bring you up to speed.
Bought a 97 Bonneville and was not going to mod it. My dickbag friend told me about an ebay auction for a pulley and puller, that was the end of stock.
Final build on the motor:
Stock bottom end
S1X camshaft
PRJ S3 heads (stock gaskets, arp stud kit)
130# springs (fresh valve seals)
Titanium retainers
HD locks
1.8 HS rockers (comp bolts)
Ported LIM with coolant mods (see prepping an LIM)
Meziere EWP
Bonneville PS relocation bracket (moves ps back 1-1.5 inches for better belt path with EWP)
8 Rib SC belt and pullies
WBS S3 IC
Gen V with 2.9" pulley
Northstar TB
4" FWI
SLP headers
Aluminum Bonneville oil pan, pickup tube and filter adapter (2000-2003)
42.5lb injectors
PRJ fuel rails
PRJ plug wires with labels and protective boots
Oversized El Dorado radiator
2000 Bonneville Alt bracket and alternator with voltage sense added
258mm flex plate drilled for 245mm.
Trans
Fully built each time.
Intense input shaft
3.29 gearset with 7/8 chain
hardened 4th hub shaft
Tightened up clutch packs
Upgraded/New valve body and channel plate
245mm torque converter
The problem
I ended up building two different transmissions for this car. The first one was out 6 or so times to be fixed. Each time the Input Shaft reluctor was ripped off the drive gear. This includes the recluctors that were screwed on by Intense, stockers and the tighter drilled one from TEP. In the three builds, the 7/8 chains were stretched. The last one being the lowest mileage (~2K miles total) and the worst of all.
Here's some pics.
One reluctor
The corresponding channel plate that it dug up
Next
The last trans I built
2K miles later
The chain where my finger is..should be at least 1/8" from the case. To reuse per the ATSG manual. It was easy to bottom it out.
It dargged
When I felt the noise after the upteenth rebulld I said I was demodding and done building a 3800 in one of my cars. I'm currently driving a mild Regal with a set of rockers and after it's first transmission (189K miles) I will put a Gen V on it. That's as far as it will ever go.
I am considering asking the machine shop if they can weld the reluctor onto the drive gear to keep this from ever happening again in my "mild" setup.
