will i be able to see the threads when i take off the small bolt on the supercharger?
Yes
Do i need to use this mounting hardware for the gauges? the gauges seem to fit pretty tight in the a-pillar as itself
If you're talking about the back bracket, no. I didnt, I really had to force mine in there. They're not going anywhere.
My gauges stay on constantly. whats the deal with that?
Your 12v switched wire is seeing constant 12v
I got it fixed. Where can I feed the hose for boost through the firewall? The hose doesn't seem very long
That is gonna be a pain in the ass. There is a rubber grommet under the brake booster, in this general area.( but lower, beneath the brake booster) You can find it by following the large wire harness that goes through your firewall.
http://i1214.photobucket.com/albums/...f839df49-4.jpg
Or, if you go and buy a hose that is about 8ft long, you can go through your passenger side, where they ran your amps power line. I went through under my brake booster, and it is a bĂ*tch.
Oh god. I'll see what I can do. Not to excited about this
