I have a 98 GTP with 140k miles.
Upon acceleration (hard or soft) from a stop, the entire front end shakes violently. It has always felt like wheel-hop.
This has grown worse to the point where instead of being sporadic, it's persistent.
I had my wife drive it while I watched. I confirmed that the front wheels are hopping. They're acting as if they're torsional springs - they spool, release, hop, then regain traction. It can shift from L to R as it spools and then unloads.
I've replaced the front shocks with monroe quick struts, the front stabilizer with Dorman and moog poly inserts/links.
Is there anything I can do to stop this?
It seems to be worse now that my pass front tire is VERY bald (will be replaced soon).
Could it be something like a tranny mount?
I've checked the halfshafts and all other suspension/power components and I just don't see anything wrong. I've not looked for the tranny mount, so for all I know it could be shot (I presume it's a rubber/poly mount that could be rotted).
The cradle mounts are fine, and all other rubber components that I can see are also fine. I also checked the tranny etc - it works flawlessly (fluid just changed, no slipping etc).
Any ideas?
