Thread: Looking for extra power at the drag strip
Results 21 to 40 of 44
  1. #21 Re: Looking for extra power at the drag strip
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    Has anyone ever got the whole kit because if I'm thinking right with the wet kit I'm going to need some sort of aftermarket fuel rails that have an fittings
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  2. #22 Re: Looking for extra power at the drag strip
    Grand Island, Nebraska
    Well you need an aftermarket fuel rail with an intercooler also.
  3. #23 Re: Looking for extra power at the drag strip
    Panama City Beach, FL
    Quote Originally Posted by shawnschuldt View Post
    Just use a -4 at the Fuel rail test port.
  4. #24 Re: Looking for extra power at the drag strip
    Jun 2010
    Beloit, WI
    Quote Originally Posted by 02 WS6 TA View Post
    That's a great idea till I get some rails thanks
    --00 Red GTP--
    13.07@108mph
  5. #25 Re: Looking for extra power at the drag strip
    Don't forget to remove the schrader.
  6. #26 Re: Looking for extra power at the drag strip
    Jun 2010
    Beloit, WI
    Lol that would definitely be a rookie move, bright side would be I would never have to refill the bottle
    --00 Red GTP--
    13.07@108mph
  7. #27 Re: Looking for extra power at the drag strip
    Well, rookie moves have happened before, as I suspect is the case here. I meant the fuel schrader- A wet kit is far less destructive when introduced with a ration of fuel present.
  8. #28 Re: Looking for extra power at the drag strip
    N2O master right here^
  9. #29 Re: Looking for extra power at the drag strip
    Jun 2010
    Beloit, WI
    Lloyd I know what u meant, its something I prolly would have did.
    Quote Originally Posted by JoRoW99 View Post
    I believe anyone who can pop wheelies
    --00 Red GTP--
    13.07@108mph
  10. #30 Re: Looking for extra power at the drag strip
    Yoga city
    Take the pulley off and run it on the hub
  11. #31 Re: Looking for extra power at the drag strip
    Quote Originally Posted by Jteske88 View Post
    Best advice in this thread.
    yeeeeeeeeaaaaaaaaaaaaaaaaaahboutthat
  12. #32 Re: Looking for extra power at the drag strip
    GTX Level Member real diehl's Avatar
    Salina, KS
    Sticky tires.
    Best strip mod.
    signature removed for inappropriate content.
    -bio
  13. #33 Re: Looking for extra power at the drag strip
    Only you, Kooks, BMR, and my paint guy think that's neat. My wallet thinks it is rookie.
  14. #34 Re: Looking for extra power at the drag strip
    Bunnell, FL
    Dead Weight(lbs):
    ___________________________________
    lexan/plexi windows 116
    ***rear window 40
    ***sunroof 24
    ***rear glass 17
    ***rear motors 10
    ***front glass 14
    ***front motors 10
    catback exhaust 65
    bumper supports 60
    ***rear bumper support 29
    ***front bumper support 23
    ***rear styrofoam insert 4.5
    ***front styrofoam insert 3.5
    passenger seat(04+) 52
    passenger seat(97-03) 42
    spare tire and jack 35
    AC system 32
    ***compressor 9
    ***duct 8
    ***condensor 6
    ***fan motors 6
    ***other parts 2
    ***controls 1
    door panels(04+) 29
    ***front door panels 15
    ***rear door panels 14
    race seat 29
    weather stripping(04+) 26.5
    aluminum cradle 26
    rear seat 26
    ***upper part 17
    ***lower cushion 9
    carbon fiber hood 25
    door panels(97-03) 25
    ***front door panels 13
    ***rear door panels 12
    race battery 26.5
    ***battery weight savings 25
    ***battery tray 1.5
    heater box 25
    carpeting 24
    ***front 8.5
    ***rear 8.5
    ***trunk 7
    insulation 23.5
    ***front 12
    ***inner firewall 4.5
    ***rear 4
    ***trunk 3
    wiper system 18.5
    ***wiper motor/bracket 8
    ***washer fluid 8
    ***washer fluid tank/pump 1.5
    ***wipers 1
    sway bars 18
    ***front 9
    ***rear 7
    ***front endlinks/brackets 1
    ***rear endlinks/brackets 1
    headliner 15
    airbags 13
    ***passenger airbag 9
    ***driver airbag 4
    underhood shields/brackets/ect. 12.5
    ***engine lift brackets/heat shields 5
    ***cross braces 3
    ***engine cover 2
    ***hood braces 1.5
    ***alternator brace 1
    ***hood cover 1
    dash paneling/covers 12
    ***glove box 5
    ***upper dash panel 2
    ***center panel 1.5
    ***gauge cover panel 1.5
    ***lower passenger dash paneling 1
    ***fusebox covers 1
    side skirts 11
    seat belts 10.5
    ***rear 8
    ***front passenger 2.5
    Bonneville coilpack bracket 10
    ABS 10
    center console 8.5
    ***console panels/wires 7
    ***center console cover 1.5
    Evap system 5.5
    ***larger evap canister 3
    ***hoses/alum tubing/other 2
    ***smaller evap canister .5
    headunit 5
    rear mud flaps 5
    lower front bumper panel 5
    headlight(04+) 4.5
    upper motor mount 4.5
    floor mats 4
    ***front 2.5
    ***rear 1.5
    HUD box 4
    front mud flaps 3.5
    EGR system 3.5
    cruise control box 3
    fog lights(04V6+) 3
    Onstar box 2
    air tubes 1.5
    rear spoiler 1.5
    horn 1.5
    front fascia 1
    rear view mirror 1
    rear fascia 1
    rearspkrs/amp 1
    rear paneling/speaker cover 1
    trunk cover .5
    Rotating Mass:
    skinnies 42
    Grand Am brakes 20
    front 15" rims/slicks 10
    front 16" rims/slicks 8
    lighter torque converter 6
    lighter balance shaft 5
    I'm a Sex Offender
  15. #35 Re: Looking for extra power at the drag strip
    My onstar box weighed more than 2 lbs i can tell you that.
  16. #36 Re: Looking for extra power at the drag strip
    Jun 2010
    Beloit, WI
    question for those who suggested the 3.0 pulley i did put it on today and with some tuning i have bad kr on shifts now, do you this this is the result of the only torque management i left on. Or do you think i need to change my plugs to 103's?
    Mind you i run my current setup on 20* of timing i wouldnt think it would be such a substantial amount of knock for that pulley drop.
    And to add to the confusion in my scans for my 3.0 and 3.25. i can pull up my knock at certain boost levels, and i dont get knock at around 11 psi on my 3.25. well if i find the point at which my 3.0 hits 11psi there is knock
    --00 Red GTP--
    13.07@108mph
  17. #37 Re: Looking for extra power at the drag strip
    smaller pulley, more heat.
    I dont see why you're trying to push more than 10 PSI out of the M90 though.
  18. #38 Re: Looking for extra power at the drag strip
    Jun 2010
    Beloit, WI
    just taking some suggestions about being able to run the 3.0 so i gave it a shot and its not going to work unless there is something im overlooking
    --00 Red GTP--
    13.07@108mph
  19. #39 Re: Looking for extra power at the drag strip
    Jun 2010
    Beloit, WI
    well i haven't got the nitrous installed yet but im going to union grove for the test and tune today. bright side is at least ill get some time slips
    --00 Red GTP--
    13.07@108mph
  20. #40 Re: Looking for extra power at the drag strip
    Jan 1970
    Maquoketa, Iowa
    It's still hard to believe that E85 would knock on a 3.0", headers, 1.9's, 65#ers... What AFR are you shooting for or can your wideband read in lambda?
  1. Finally took my gtp to the drag strip
    By 99GPGTP in forum Off Topic Discussion
    Last Post: 07-26-2011, 10:16 AM
  2. my GTP Vs s/c Truck drag strip
    By kyleinkman in forum Track Sessions and Kills
    Last Post: 06-07-2011, 12:49 PM
  3. drag strip.
    By wlmrt6 in forum Track Sessions and Kills
    Last Post: 10-17-2010, 11:02 PM
  4. Drag Strip action in the midwest
    By Deimos in forum Shows and Events
    Last Post: 03-25-2010, 09:38 AM
  5. Drag Strip???
    By hester21289 in forum Southeast
    Last Post: 03-01-2008, 08:58 PM
