Thread: Speedo & HUD don't match
Results 1 to 5 of 5
  1. #1 Speedo & HUD don't match
    SE Level Member Whitephxaz's Avatar
    Aug 2011
    N. Phoenix
    My HUD is dead on, but my dash speedometer is showing 8mph more than my HUD, how can i get them to match?
    also in my old 99gtp, to get my DRL to turn off all i did was pull the 10amp fuse outta the glove box, in my 2001 gtp i pulled that same fuse, and there is a clicking noise comming from my colume or dash by the gauges, and the dash lights wouldn't turn on. Any suggestions on how to DISABLE my DRL's without having these problems? thanks!
  2. #2 Re: Speedo & HUD don't match
    Yoga city
    Put the fuse back in?
  3. #3 Re: Speedo & HUD don't match
    Aug 2011
    N. Phoenix
    yea sorry i wasn't clear enough for you, any suggestions on how to disable my DRL, i put the fuse back in when i heard the clicking of course
  4. #4 Re: Speedo & HUD don't match
    Yoga city
    Yes the panel that u see when you open your drivers door that's on the dash, remove it and you will see a heatsink( chunk of shiny metal) unplug the cliP to it. This will disable drls and you will still have moonlight I think it's called
  5. #5 Re: Speedo & HUD don't match
    LaBarge Supercharged sseilmnop's Avatar
    Mercer, Pa
    Is the speedometer 8 mph high everywhere? If so the pointer on the gauge needs turned relative to the shaft. Had to adjust mine a couple times after I replace some dash lights.
    Adapters, Phenolic Intercoolers, Supercharger Parts & TVS2300
    http://stores.ebay.com/QualitySuperchargers
  1. duplicolor-perfect match
    By dpzelenak in forum Off Topic Discussion
    Last Post: 05-08-2011, 12:34 PM
  2. color match
    By Tha Ghost in forum Visual/Body Modifications
    Last Post: 01-04-2011, 04:32 PM
  3. Touchup Paint Match?
    By Mark99GT in forum General Tech Discussion
    Last Post: 02-26-2010, 02:50 AM
  4. Michigan Grudge Match
    By Anthony Shaw in forum Shows and Events
    Last Post: 09-07-2008, 09:07 PM
  5. Color match or Carbonfiber
    By JCG's-GTP in forum Visual/Body Modifications
    Last Post: 03-27-2008, 11:43 AM
