Thread: Header are in! But i have some questions?!
Results 1 to 5 of 5
  1. #1 Header are in! But i have some questions?!
    SE Level Member blknbstd's Avatar
    May 2011
    Phx Az
    well yesterday i tackled my headers, plus my destroyed lower mounts/spacers and rear brakes.. everything went pretty well except the crossover was not wanting to line up but 20 min of finessing with a 2 1/2 ft pry-bar did the trick lol.. wasn't that long to do with air tools an a lift for multiple up an downs lol... woulda been a pita if i attempted this anywhere else started at 9 finished around 5.30..
    But some questions now..
    1. I'm currently running no cat and im getting p0420 i know this already.. but if its turned off from hptuners does it read so it stops dumping fuel, or just does it just disable the code from ever being set again.. or am i gonna need a wide band to tune around it..
    2. do any o2 emulators work on 04's?
    3. ive been losing a lot of low end torque ever since began modding an it all of too much exhaust flow.. Now i have headers, no cat with a 3in exhaust an 2.5 after the Y pipe
    Should i do 2.5 to at least the y to gain some of that back.. an i also plan on the 3.6 an tune within the cooler months..
    04 Comp G..... OVERKILLED/local tune water/meth 3.6, SD headers, 3in catless catback, autolite 104's lowered on SSC's and gxp brakes, DONROME STB.
    1/4mile in 14.03 at 98mph 2.4 60ft
  2. #2 Re: Header are in! But i have some questions?!
    Charles City, IA
    Run the rear 02 sensor and then disable the code.
    SMGPFC Two Nipple General
  3. #3 Re: Header are in! But i have some questions?!
    May 2011
    Phx Az
    zzps and 3800preformance say they dont work on 04s or is this just hoopla
  4. #4 Re: Header are in! But i have some questions?!
    Charles City, IA
    I think your pigtail is different
  5. #5 Re: Header are in! But i have some questions?!
    May 2011
    Phx Az
    cant i just change it to work.. i used a front o2 sensor for my rear extension but i just had to modify how it snaps in.. would this be the same
  1. sd header help
    By jerrysalley in forum General Tech Discussion
    Last Post: 03-20-2011, 11:26 AM
  2. header gasket - header clamps - kn filter
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 02-21-2011, 10:00 AM
  3. Header Questions For My 90 Chevy PU
    By mikesarebetter in forum Off Topic Discussion
    Last Post: 03-04-2010, 09:08 PM
  4. ZZP Header Questions?
    By ActionJackson1985 in forum General Tech Discussion
    Last Post: 11-07-2009, 02:13 AM
  5. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
