Thread: coolant leak
Results 1 to 5 of 5
  1. #1 coolant leak
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    just woundering how many hoses on the cooling system so i can be sure to check them all. radiator to water pump then throught the block back to the radiator.
    but how many other hoses.
    thanks
  2. #2 Re: coolant leak
    Charles City, IA
    heater hoses, coolant elbows, intake gaskets like to leak, water pump will leak.
    SMGPFC Two Nipple General
  3. #3 Re: coolant leak
    upper rad hose to LIM
    lower to water pump
    2 heater core hoses to back of the alt bracket and LIM
    and coolant elbows like to leak too
  4. #4 Re: coolant leak
    Jul 2011
    Michigan
    ok, i seem to have found the leak. coolant elbow (upper).
    but there is also a little puddle of coolant under the alternator by the intake (kinda between the intake and the valve cover but over toward the alternator). could this be from the elbow also? or the intake.
  5. #5 Re: coolant leak
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    if the puddle is in the groove of the intake i would think its the intake gasket. with the coolant elbows being bellow the intake i dont believe that coolant would travel up
  1. bad coolant leak
    By johnfolks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2011, 04:30 PM
  2. coolant leak help???!!!
    By silverbullet10 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2011, 08:10 PM
  3. Coolant leak Please help
    By KwazrollinZ28GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2011, 07:52 PM
  4. L36 Coolant Leak
    By JJ91284 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 03:41 PM
  5. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
