Thread: throttle body screen
Results 1 to 9 of 9
  1. #1 throttle body screen
    Donating Users
    Plainfield, IL
    got a 00 GTP and i took out my throttle body screen a couple days ago seems to run fine but if i leave it in park for a long time like waiting somewhere i notice every once in awhile the engine will rev a lil by itself is this bad i know that screen straightened air for the MAF but i noticed way better throttle response with it gone ....other than the rev and a little bit of shake she runs great. do i got anything to worry about? and as for the shake i had that before i did the screeen removal, what could that be? its when its hot i get motor shake is this normal? thanks any help would be good.
  2. #2 Re: throttle body screen
    Barksdale AFB, LA
    Put it back in. The little flow increase you received is not worth the risks of inaccurate MAF readings. This should be in the same category as the BBV mod and putting a resistor on the IAT sensor..
    2009 Subaru Impreza WRX STI
  3. #3 Re: throttle body screen
    Apr 2008
    Chillin at the Beach , VA
    Exactly. I did this many moons ago before I found this forum and had to learn the hard way. Mine ran fine when first done, but the longer it was out, the worse my idle got.
  4. #4 Re: throttle body screen
    Donating Users
    Plainfield, IL
    cool thanks man
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  5. #5 Re: throttle body screen
    Donating Users
    W-S, NC
    Quote Originally Posted by BADAZGTP View Post
    Mine was starting to do the same, sounded like I had a mild cam in at idle. I put mine back in and its running like it should. Its better to have the screen in place esp. when it come time for you to start tuning your pcm.
  6. #6 Re: throttle body screen
    Apr 2008
    Quote Originally Posted by Boger's99GTP View Post
    I used to love sitting a light with it doing that and everyone looking at you like what the hell is under the hood. But, yeah, I'd rather have the smooth idle.
  7. #7 Re: throttle body screen
    Donating Users
    W-S, NC
    last week before I replaced mine, I was going thru a wendy's drive thru, I pull up to the window the guy looks at me with big eyes hold his hand to his ear and says that no normal grand am(yes I type exactly how he said it), I said yep your right..cause it a grand prix.... Dumba$$.
  8. #8 Re: throttle body screen
    TDCRacing
    Guest
    Yep leave it in.
  9. #9 Re: throttle body screen
    Donating Users
    Plainfield, IL
    wow it was def messing up my MAF the throttle response may have been a lil quicker but wow i was def losing HP i drove with it back in today and it pulls way harder....oh will by the way off topic but i got an aeroforce off my friend and when its hooked up through OBDII power in his car it works but when i have the jumper removed and have it hooked up using add a fuse in my GTP i get nothing no light no power any ideas?
  1. throttle body fluid?
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2008, 10:56 PM
  2. Stock Throttle Body O.D.?
    By IndeedSS in forum General Tech Discussion
    Last Post: 09-03-2008, 04:26 PM
  3. Throttle Body Spacer
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 06:21 PM
  4. Can I remove the throttle body screen??
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 09:00 AM
  5. HV throttle body for the L36
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:34 AM
