Thread: 98 gtp Odd stalling, changed crank sensor
Results 1 to 9 of 9
  1. #1 98 gtp Odd stalling, changed crank sensor
    Jul 2011
    Franklin
    I have a 1998 pontiac grand prix gtp. I have only had it about a month. It had a small miss so I put plugs and wires on it . Since then it dies at a stop and the rpms drop suddenly on and off. I have changed all the censors under the hood including crankshaft positioning censor. I have also put new coil packs on it. It isnt throwin any codes. I have also checked the intake gaskets. IM STUMPED! ! ! Please help!
  2. #2 re: 98 gtp Odd stalling, changed crank sensor
    did the misfire go away?
    you could clean the throttle body if you haven't, there's a write in the how to section.
  3. #3 re: 98 gtp Odd stalling, changed crank sensor
    Texas
    Before you started throwing parts at it did you check the GM service manual and diag it? Or did you take a multi meter and do some tests?
    Did you hook a scanner up to it to see if it's misfiring and if so which cylinder?
    Have you tried doing a compression test on it yet?
    85 Corvette
    01 TA
    03 Z06
  4. #4 re: 98 gtp Odd stalling, changed crank sensor
    Jul 2011
    Franklin
    It isnt throwing any codes and the missfire did not go away. Thats what I dont understand. I have had it in the shop and know one seems to know why its actin like that. Ill try to clean the throttle body tomorrow.
  5. #5 Re: 98 gtp Odd stalling, changed crank sensor
    You say you've changed a bunch of stuff. Please elaborate.
    I see
    Crank shaft sensor
    Coils
    Have you checked the ICM? These are tough to test, as they will often test fine and only act up when hot.
  6. #6 Re: 98 gtp Odd stalling, changed crank sensor
    its AWDsome JarenSTi's Avatar
    Hawaii
    possible maf sensor? i had the same problems.
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  7. #7 Re: 98 gtp Odd stalling, changed crank sensor
    Jul 2011
    Franklin
    I have checked the maf sensor. And the thottle positioning sensor.
  8. #8 Re: 98 gtp Odd stalling, changed crank sensor
    chicago
    Check the fuel pressure regulator.. remove the little vacuum line attached to it and if even one little tiny drop of gas comes out means you need a new one.. mine was doing the same thing just randomly dying and dropping RPM's.. changed it last week and runs like a champ now
  9. #9 Re: 98 gtp Odd stalling, changed crank sensor
    Jul 2011
    Franklin
    ok ill try it thanks
  1. crank position sensor?
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 12:45 PM
  2. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  3. 3.1 crank sensor wire
    By 68galaxie500 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-22-2010, 09:18 PM
  4. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
