Thread: low coolant level sensor
Results 1 to 8 of 8
Jgackle low coolant level sensor 08-09-2011, 12:38 PM
TheOtherNick Re: low coolant level sensor 08-09-2011, 12:40 PM
Zef_66 Re: low coolant level sensor 08-09-2011, 01:55 PM
Jgackle Re: low coolant level sensor 08-09-2011, 03:04 PM
Scottydoggs Re: low coolant level sensor 08-09-2011, 03:13 PM
1996pontiac Re: low coolant level sensor 12-31-2012, 09:45 AM
MoarkatsINmuhtrailer Unplug the sensor. 12-31-2012, 09:52 AM
dsmuts Re: low coolant level sensor 12-31-2012, 01:31 PM
  1. #1 low coolant level sensor
    Jul 2011
    mn
    2001 Pontiac Grand Prix third owner, 144K miles. 3800 series II, not S/C.
    Low coolant light came on, coolant level was okay, replaced sensor, unhooked battery to clear, coolant light went out, now it comes on when not touching the throttle, when accelerating it goes out. Now it stays on again continuously. Coolant level is okay, system has been bled.
    Any thoughts?
  2. #2 Re: low coolant level sensor
    Charles City, IA
    Unplug the sensor.
    SMGPFC Two Nipple General
  3. #3 Re: low coolant level sensor
    GXP Level Member Zef_66's Avatar
    PA
    The sensor can go bad or even just get dirty and cause issues like you are seeing. Yes, unplugging it will make it go out. But you also try to remove and clean the sensor and the hole it goes into.
    You can also replace it with a new one from the parts store. They usually run around $25-30.
    2001 GSE
  4. #4 Re: low coolant level sensor
    Jul 2011
    mn
    It was a new one, it was clean and so was the hole
  5. #5 Re: low coolant level sensor
    try checking the wires off the plug for cracks or missing insulation, there also could be somewhere that's rubbed through the wires too.
  6. #6 Re: low coolant level sensor
    GT Level Member 1996pontiac's Avatar
    Livonia, Michigan, United States
    i have the same problem with my 99 gtp S/C. I replaced the sensor and the light is still on. My issue is i can't stand lights on my dash. When they come on i need to replace the problem. Drives me nuts.
    1999 Red Pontiac Grand Prix GTP/120xxx miles
    Mods- Intake
    Ohio
    Unplug the sensor.
  8. #8 Re: low coolant level sensor
    This ^^^ I've done it on a few
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. how do you disconnect the oil level sensor from the oil pan.
    By 98regalgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2010, 07:06 AM
  3. coolant level sensor, you gotta be crapping me!
    By Teardrop in forum The Rant Forum
    Last Post: 09-12-2010, 09:17 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  5. dumb coolant level question
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2010, 02:32 PM
