Thread: No power to fuel pump relay from PCM? *Update issue resolved*
Results 1 to 20 of 31
Threaded View
txslow6 No power to fuel pump relay... 07-27-2011, 04:42 PM
matt5112 Re: Racetronix pump installed... 07-27-2011, 05:02 PM
txslow6 Re: Racetronix pump installed... 07-27-2011, 09:14 PM
BillBoost37 Re: Racetronix pump installed... 07-28-2011, 06:28 AM
txslow6 Re: Racetronix pump installed... 07-28-2011, 09:29 AM
matt5112 Re: Racetronix pump installed... 07-28-2011, 09:34 AM
txslow6 Re: Racetronix pump installed... 07-28-2011, 09:35 AM
txslow6 Re: Racetronix pump installed... 07-28-2011, 11:42 AM
RegalGS98s Re: No power to fuel pump... 08-01-2011, 11:43 AM
txslow6 Re: No power to fuel pump... 08-01-2011, 01:35 PM
txslow6 Re: No power to fuel pump... 08-01-2011, 06:40 PM
RegalGS98s Re: No power to fuel pump... 08-03-2011, 02:25 PM
darkhorizon Re: No power to fuel pump... 08-03-2011, 05:47 PM
txslow6 Re: No power to fuel pump... 08-03-2011, 10:14 PM
txslow6 Re: No power to fuel pump... 08-04-2011, 11:08 AM
brandonl2000 Re: No power to fuel pump... 08-04-2011, 01:55 PM
txslow6 Re: No power to fuel pump... 08-04-2011, 05:34 PM
darkhorizon Re: No power to fuel pump... 08-04-2011, 02:14 PM
RegalGS98s Re: No power to fuel pump... 08-05-2011, 10:02 AM
brandonl2000 Re: No power to fuel pump... 08-04-2011, 08:02 PM
matt5112 Re: No power to fuel pump... 08-04-2011, 09:41 PM
txslow6 Re: No power to fuel pump... 08-04-2011, 10:38 PM
JcGTP39 Re: No power to fuel pump... 08-07-2011, 07:42 PM
matt5112 Re: No power to fuel pump... 08-04-2011, 10:44 PM
txslow6 Re: No power to fuel pump... 08-05-2011, 07:18 AM
matt5112 Re: No power to fuel pump... 08-05-2011, 10:05 AM
brandonl2000 Re: No power to fuel pump... 08-07-2011, 08:01 PM
txslow6 Re: No power to fuel pump... 08-07-2011, 08:36 PM
JcGTP39 Re: No power to fuel pump... 08-07-2011, 08:51 PM
brandonl2000 Re: No power to fuel pump... 08-07-2011, 09:05 PM
JcGTP39 Re: No power to fuel pump... 08-10-2011, 09:23 AM
  1. #1 No power to fuel pump relay from PCM? *Update issue resolved*
    Texas
    Switched to a racetronix pump and the pump isn't priming. The one before had stopped and wasn't priming either.
    I have tried with the caspers rewire and the factory wiring and still no luck. The fuel pump fuse is good. What should I check next?
    I will be pulling the pump back out to double check connections, but in the meantime any suggestions?
    85 Corvette
    01 TA
    03 Z06
  1. Installed OEM Nav
    By richhurl in forum Audio, Security & Visual Electronics
    Last Post: 11-06-2010, 08:20 PM
  2. fuel pump? not priming
    By 99prixgt in forum General Tech Discussion
    Last Post: 10-10-2010, 05:47 PM
  3. Fuel pump not priming HELP!
    By ls6velless454 in forum General Tech Discussion
    Last Post: 09-19-2010, 04:45 PM
  4. Racetronix Fuel pump canister install questions...
    By Iron Indian in forum General Tech Discussion
    Last Post: 05-18-2009, 12:11 AM
