Thread: exhaust smell
Results 1 to 7 of 7
  1. #1 exhaust smell
    SE Level Member KadenGT's Avatar
    Jul 2011
    wisconsin
    when im at WOT i get a strange smell in my car im sure its my exhaust (i know WOT means more exhaust flow) but why does it have a smell to it? none of my other cars had a smell when i went WOT
  2. #2 Re: exhaust smell
    Florida
    possibly a small leak, but then you'd have a little 'tick' at idle.
    Cat could be on its way out....
    But then again, everytime I mashed the gas in my GT, it'd smell that way.
  3. #3 Re: exhaust smell
    Nov 2008
    Hillside
    if it smells sweet, your head gasket is going.
  4. #4 Re: exhaust smell
    Kansas
    Quote Originally Posted by wenlyone View Post
    Headgaskets very rarely go out on these cars. Is the smell like a rotten egg, or nasty smell?
  5. #5 Re: exhaust smell
    Jul 2011
    wisconsin
    not rotten eggs but just it isnt very pleasant smelling either
  6. #6 Re: exhaust smell
    Yoga city
    Dead animal Or your grandma's feet unpleasant smell? Well man, describe!
  7. #7 Re: exhaust smell
    1. At WOT you are likely traveling so fast that you can't smell anything but the sewage plant you are passing.
    2. The exhaust should exit out the rear of the car. Unless you are WOT in reverse, or have a huge loud leak in the front...you should never be able to smell the exhaust
    3. I dislike Wenly for not knowing our engine before suggesting such a thing.
    4. Airflow.. see #1 and choose a different road for your WOT runs.
    5. You likely need to check your valve cover gaskets. But see #1.
  1. ? If Hot could have a smell 97 GTP
    By JoshsGTP in forum General Tech Discussion
    Last Post: 08-16-2010, 02:11 PM
  2. Bad Smell
    By GMPUNK in forum General Tech Discussion
    Last Post: 07-08-2009, 04:50 PM
  3. Faint smell of antifreeze in exhaust
    By firstdue in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2009, 09:00 PM
  4. Burning Oil Smell
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2008, 01:07 PM
