Thread: Leaking Anti Freeze from hose and under the car from engine area. Please help!
Results 1 to 3 of 3
  1. #1 Leaking Anti Freeze from hose and under the car from engine area. Please help!
    Jul 2010
    Canada
    I was driving home today and my car overheated so I put some water in just to get me home. When I got home I looked to see where the leak was coming from and it was dripping from the hose that goes from the radiator to the engine. It was also leaking from underneath the engine but I couldnt see from where exactly. Obviously I need a radiator hose to stop the leak but how about under the engine what could that be from??? Any help would be much appreciated.
  2. #2 Re: Leaking Anti Freeze from hose and under the car from engine area. Please help!
    Jul 2010
    Canada
    This is a 2004 Grand Prix
  3. #3 Re: Leaking Anti Freeze from hose and under the car from engine area. Please help!
    Topeka, KS
    If your waterpump had issues you'd hear noises. I bet its hoses or coolant elbows. I'd replace the hose first and go from there. 2 Pressure clamps and your done. Also look at the coolant elbows that go through the alternator support bracket. Those get old and crack with age\heat.
    Your going to have to drain your radiator for that bottom hose though. And purge your system for air after replacing your hoses, ect.
    Go to your favorite autoparts store and buy a jug or two of Dexcool, a catch can that can hold a gallon or more of antifreeze, and a radiator hose. It may not hurt to do both at the same time. The top one is really easy.
  1. 3.8 supercharger freeze up
    By tammy in forum General Tech Discussion
    Last Post: 06-18-2011, 09:38 AM
  2. Freeze frame, what does all this mean?
    By khung88876 in forum General Tech Discussion
    Last Post: 06-05-2011, 01:47 AM
  3. Changing Freeze Plugs
    By tmackster in forum General Tech Discussion
    Last Post: 02-06-2011, 11:44 PM
  4. Anti Freeze Leak
    By JB381 in forum General Tech Discussion
    Last Post: 02-26-2010, 09:00 PM
  5. Oil "Leak"/Anti-freeze dump
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 08:06 PM
