Thread: Remote Program
Results 1 to 3 of 3
  1. #1 Remote Program
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    I'm trying to program my new remote and cant get it to.
    1. Remove the key from the ignition.
    2. Close all doors.
    3. Remove the "MALL PGM" fuse from the fuse panel. Use the legend on the fuse panel or
    owner's manual to properly locate the "MALL PGM" fuse.
    4. Insert the key into the ignition, and turn to the ACC position.
    5. Turn the key to OFF and then back to ACC within 1 second.
    Cars beeping during this step too
    6. Open and close any vehicle door. A chime will be heard when the system enters into
    programming mode.
    After this step the car keeps beeping
    7. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
    IMPORTANT: After 7 seconds, a chime may be heard confirming successful
    synchronization. It is necessary to wait approximately 14 seconds for a second chime
    that will confirm successful programming.
    8. Repeat step 7 now for each additional remotes to be programmed including any existing
    remotes.
    9. Remove key from ignition.
    10. Install the "MALL PGM" fuse back into the fuse panel and test remote(s).
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  2. #2 Re: Remote Program
    Yoga city
    Did u check your rpo codes to see what bcm it has? And if maybe bcm is bad
  3. #3 Re: Remote Program
    Jun 2011
    Watertown, SD
    Which RPO Number is it?
    http://s522.photobucket.com/albums/w348/grandamle91/
    My remote that I bought is: GM/LEAR 10443537
    Heres a video of what it does
  1. ? How do i program a new key fob?
    By 937Crizzle in forum Audio, Security & Visual Electronics
    Last Post: 08-04-2019, 06:26 PM
  2. Remote Won't Program!
    By ljmonnin12 in forum Audio, Security & Visual Electronics
    Last Post: 03-16-2011, 09:03 PM
  3. How do you program a Viper 479V remote?
    By 007 in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2010, 12:53 PM
  4. can anybody help me program my pcm
    By shawn in forum PCM Tuning
    Last Post: 08-09-2008, 11:51 AM
  5. program a fob??
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 07-07-2008, 10:22 AM
